Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman riding lawn mower wheel toe needs adjustment.
The right front wheel is now facing about 10 degrees to the right as a result of striking a wall while turning. Nothing appears bent or damaged. Can I make this adjustment?
  • chappi4u May 19, 2009
    OMG, why didn't I think of that! You so bright mjlux, I can see you from here. Thanks for the help.
    Problem Solver:
  • 6 Answers
Put it in reverse ton the wheel to the right and hit the wall again....or ir you were backing up when u hit the wall runn into foward
Posted on May 19, 2009
I have a craftsman revolution riding mower and its having troubles turning to the left. model 247.28933 any ideas??
Check the steering rack cogs r
Are not missing each other as you turn the wheels left if the teeth gap increases as the wheels turn the rack is worn and will need adjusting so the teeth meat better or the rack will need to be replaced this . Part can be quite expensive I had a countax ride on same problem would not turn to the left easily or the steering wheel would just spin. Around but the front wheels did not move until you pushed them by hand 're engaging the cogs on the rack it was nearly £ 596+ vat just the parts needed to repair it
Jun 26, 2016 | Craftsman Revolution 42" Briggs Stratton...
Ariens 42" lawntractor front wheels aren't straight
adjust the toe in -out and if they lean in at they top check bearings or king pin wear
toe in should be slightly in at the front(1/8 ") and wheels straight up and down
May 06, 2016 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
How to adjust toe-in on garden tractor
cant adjust unless the tie rod ends are adjustable
you have to replace link arms ,they are bent
Oct 21, 2015 | Craftsman Kohler Courage 26 hp 54" Garden...
look at the tie rod ends . they are adjustable .
Oct 21, 2015 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
How to adjust front wheels toe in riding lawnmower
There is no adjustment. You can only replace bent and worn parts.
Nov 22, 2014 | Craftsman Garden
Undefinedright front tire out of line,l-130 riding lawn momer .right front
If the tie rod end has been changed, you will need to adjust the toe in by dropping the tie rod end from its connection to arm. Not the steering rod. Tighten or loosen the tie rod end on the steering rod until there is a slight toe in. Re install the tie rod end into the steering rod. If there is too much toe in, the wheels will spread when in reverse and steering is impossible. It may take several attempts to set the toe in properly. When proper adjustment is met, steering will be easier or as it should be.
Oct 16, 2014 | John Deere Garden
Adjusting tow in on craftsman pro riding lawn mower
You can try streightening the steering link rod. or just buy a new one. also make sure the holes on the axle brackets arent wallard out.
Jun 30, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Front tires out of alignment
On page 24 of your owners manual, it states that front wheel toe-in and camber are NOT adjustable.
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_AAaa/HUSO2011_AAaa_YTH24V48LS_532445054.pdf
Sep 13, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My lawn tractor pulls to the right when driving can i fix this?
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Jun 12, 2011 | Garden
Adjusting front wheels
Grease the zerks with a general grease, tighten any loose points, check your wheel bushings. They might be worn, causing the wheels to camber or off-toe.
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
1,178 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
