Question about Toys
My kota triceratops head won't rise, missing spring?
My kota triceratops sings, moves, and blinks, so does what it should, however the head does this all facing downwards, it never rises, though moves side to side. When I lift it manually it works. so nothings blocking it.Im not sure if there is a spring/coil or gear that isn't working or there anymore. Does anyone know what makes the head rise?Thank you
SOURCE: hi my helicopter is 9053 , my helicopter working
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
Posted on Aug 21, 2010
  • 3 Answers
SOURCE: hi my daughter got the Disney Princess Magic Rise
just squeeze the air out of the cake, position the circle on the bottom of the cake onto the circle in the oven, wave the wand over the heart or press the heart and it should rise in 5-30 seconds
Posted on Dec 29, 2010
alicantecoli
  • 22326 Answers
SOURCE: cake just won't rise... oven
what about the yeast riser powder in the mix ,or use self raising flour
Posted on Jan 05, 2011
SOURCE: Disney magic rise oven--the cake
The muffin is controlled by using magnets. Get any magnet and put it on the bottom part of the muffin and the muffin should inflate. If not, you can remove the bottom plate on the bottom and manually remove the plunger inside.
Posted on Oct 10, 2011
SOURCE: Can you get a replacement leaf for the big Kota
He can eat anything its not like the leaf has a magnet or anything if you put something in his mouth like your hand even, there is a little button/switch whatever on the roof of his mouth that causes him to eat
Posted on Nov 21, 2011
How can I fix the tail of the playskool Kota triceratops?
If you can open Kota up (remove the fabric & unscrew whatever pieces),
you might be lucky enough to unjam it, or to move & re-align the gears.
There may be a spring that pushes one or both of the gears together that
may need to be checked too. If the gear teeth are OK but some other
part is broken, you can use 2-part epoxy from Walmart, Michaels, etc.
to fix it. Superglue will not work as it is too weak & brittle.
If the teeth on the gears are stripped, it will be tough. You can try rebuilding
the teeth with 2-part epoxy PUTTY (not glue) or 2-part plumbers putty from
Osh, Home Depot, or Michaels (Mighty Putty). and it may break again,
It might be easiest to call the company and ask about repairs and/or
replacement parts. Good luck!
Dec 01, 2016 | The Toys
How to fix my kota triceratops neck?
New you tube video 2:50 min video called Kota dinosaur
broken/hanging neck repair
Jan 16, 2016 | Hasbro Playskool Kota and Pals Stompers -...
How can I get an instruction manual for Playskool Kota dinosaur
Hasbro has the instructions and replacement parts for many of the Playskool toys on their support site, http://www.hasbro.com/site-map.cfm . The instructions for the Kota the Triceratops are available here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/61EED7975056900B10DED12F214D6B3E.pdf . The instructions for the Kota and Pals Ankylosaurus are here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/F235292B5056900B10B29E652C4640C1.pdf . However, they do not have any parts for the Kota and Pals set. You may find the leaf available in an internet auction.
I hope this helps.
May 01, 2014 | Hasbro Playskool Kota and Pals Monty T-rex...
HI, I would like to clean Kota...got any suggestions? Thanks, Terri
  • How to Wash Stuffed Animals ' eHow.com
    • By eHow Hobbies, Games & Toys Editor ·
    • Difficulty: Moderately Easy
    While there are many methods of cleaning stuffed animals, experts agree on one thing: always be gentle when cleaning vintage stuffed animals. Some experts may ...
    www.ehow.com/how_2054654_safely-wash-stuffed-animals.html · Cached page
  • Cleaning Stuffed Animals Cleaning Stuffed Animals, How to wash and clean stuffed animals.
    www.stretcher.com/stories/980813b.cfm · Cached page
  • The Best Way to Clean Stuffed Animals ' eHow.com Stuffed animals pick up dust and dirt easily. If you are an allergy and/or asthma sufferer, this can have negative effects on your health. Cleaning stuffed animals ...
    www.ehow.com/way_5272684_way-clean-stuffed-animals.html · Cached page
  • Cleaning Tips: How To Clean Stuffed Animals A stuffed animal offers unconditional love. The least we can do is keep them clean and dust free. Advice for cleaning different materials.
    www.essortment.com/cleaning-tips-clean-stuffed-animals-58624.html · Cached page
  • Sep 18, 2011 | Hasbro Playskool Kota and Pals Stompers -...
    My Kota Triceratops's neck is broken and she can not sing anymore. Still blinks, moves horns, wags tail and open and closes her mouth. No sound
    The neck is not moving up it just stays down while he talks, blinks, and looks side to side;
    any solutions?
    May 03, 2011 | Toys
    Need a user guide for kota
    Dec 15, 2010 | Hasbro Playskool Kota and Pals Stompers -...
    Jul 23, 2010 | Playskool Toys
    Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
    I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
    Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
    Toys Logo
    51 people viewed this question
    Top Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Toy Expert? Answer questions, earn points and help others
