Question about Zanussi Washing Machines
Zanussi zwg5125 fabric softener still in drawer
Fabric softener is still in drawer at end of cycle
4 Suggested Answers
  • 6277 Answers
SOURCE: The fabric softener drawer on
It is not that unusual to find some plain water remaining- has the softener gone OK?
If not here is just a quick POSSIBLE (1st) solution if you have not tried it already-
Completely slide out the drawer - normally made possible by pressing down the plastic flap at the backend of the softener part of the drawer - as it is normally in the middle.
You may find 'gunge' made up of washing powder (if you use powder of course!) and softener combined in the tube that the softener should syphon into. Wash out with plenty of water!
I do this to ours fairly frequently.
Hope this helps.
Posted on Jan 22, 2011
  • 6277 Answers
SOURCE: fabric softener still in drawer at end of any
Although you do not say which model it is, this is a common problem with many machines.
I suspect (first) that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of those should enable you remove it
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 07, 2011
vko007us
  • 254 Answers
SOURCE: My Zanussi ZWF 1421 washing
plz try this link:
http://www.manualsmania.com/model.php?model=2d43f0305358baa1c874c2818d8c4834fade996
hope it helps u out..if not plz revert
Posted on Aug 21, 2011
Fabric softener drawer water residue after washer completed cycle
This is probably due to a build up of residue of softener. Remove the drawer, strip the bits off, and clean with a toothbrush. Then replace, and this should solve the problem.
Apr 11, 2015 | Zanussi ZWF1430W Front Load Washer
Why does water softener drawer still have water in it at the end of cycle
It is clear water right? The filler tube flushes as it empties and it always has a small amount of flush water in it.
Jul 26, 2014 | Zanussi Washing Machines
Why is fabric softener still in drawer after cycle?
there is usually a piece of plastic that hangs over the edge of the conditioner drawer that acts like a siphon when it is filled. this sometimes comes off or is lost when the drawer is taken out for cleaning. if you input your make and model on espares, they may have replacement part.
if you cant source one. forget conditioner and buy an all in one washing liquid
May 25, 2014 | Daewoo Washing Machines
No fabric softener dispenser
In law, within the UK, a Landlord must supply replacement items that have an instruction manual and must function fully in a state of good repair.
Spares will be available for it espares.co.uk is a good place to start.
You don't state where you are.
May 02, 2017 | Zanussi FS1455W Front Load Washer
The fabric softener drawer does not empty after a washing cycle so how do I solve this
It is normal for some water to remain in the fabric softener dispenser after the wash cycle is complete
Jan 10, 2013 | Washing Machines
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
Mar 22, 2012 | Washing Machines
My washing machine fabric drawer is blocked have cleaned complete drawer but still fabric softner is in the drawer at the end of cycle .
Pull the little 'hat' off it's post in the fabric softener compartment. Clean off any softener residue and return.
Mar 17, 2010 | Hotpoint Washing Machines
Will not take softner?
clean the dispenser drawer, then using thin pipe cleaner clean the two outlets that fall over the softner drawer, its easier if water is flowing from them, to do this switch on the servvice cycle (no clothes in the machine) as u swtich it on, hold the start pause and skip button down and then press the fabric button repeatedly until the water comes through the outlets over the softener compartment.
to exit service cycle u must swtich the machine on and off twice
Dec 28, 2009 | Zanussi FJS1225W Front Load Washer
Fabric softener tray doesn't drain
what u need to do is take your soap drawer out take it to the sink now take your fabric softener draw out the pipe that is fixed into the main drawer will need cleaning out has this will be slightly blocked with thick softener or powder once all the main drawer is cleaned do the same with the softener drawer put it back together and it should stop it from blocking up again m8
Sep 29, 2007 | Zanussi FLA1001W Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
