Question about Boston Acoustics Recepter Clock Radio
Heavily distorted sound - Boston Acoustics Recepter Clock Radio
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Sound output is heavily distorted.
Check following things:
1. The master volume control on the SR16 is at least half way up. Turn down the amp as needed. Running very low output of the SR16 and high amp gain is sure to get distortion.
2. Check power adapter is the original and is producing correct voltage.
3. Check that audio cable is high quality instrument cable and not consumer or speaker cable.
May 05, 2010 | Alesis Sr 16 Stereo Drum Machine
03 Astro rumbles heavily when stopped while drive
Sounds like it could be a bad mount. Maybe engine, tranny, exhaust??
Jul 10, 2009 | 2003 Chevrolet Astro
Have dropped my laptop and the sound is intermittently slow and heavily distorted
You'll need to replace the motherboard, the computer does not have a separate sound card. Very expensive to fix unless you can do the work yourself.
May 31, 2009 | Packard Bell (030069) Sound Card
Speakers are smoking
Do they still play? if they do then don't turn them up so loud. What that smoking is, is the coating on the voice coil turns being burned off. It happens when you are over powering or distorting the speaker very heavily. I would recommend more easy listening. Good luck.
-Andrew Hawkins
Sep 04, 2008 | Car Audio & Video
JBL PSW D112 Distorted Sound
your memory is low on resources need to increase memory.everything on ur pc uses mem.audio and video devices use an aweful lot.if you have open another program not only will ur audio be distorted but ur other program will be running slow.
correct? need to add more ram.
Mar 07, 2008 | HP Pavilion dv4000 Notebook
Laptop problems after changing cpu
Are you sure the CPU is compatible with your notebook?  What kind of notebook do you have?
Oct 18, 2007 | Toshiba Satellite A35-S159 Notebook
Can't record or take photos
Yet another CCD sensor problem ( in your case it is outputting nothing so you get blank screen as opposed to heavily distorted picture which is also very common). Properly manufactured sensor lasts 10 years + so you should have this repaired free of charge if you can. Replace CCD block.
Sep 06, 2007 | Canon MV650i Mini DV Digital Camcorder
Boston Acoustics Recepter Clock Radio Logo
51 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
