Question about Whirlpool Duet GHW9150P Front Load Washer
Electrolux brazil ewf 1010 - Whirlpool Duet GHW9150P Front Load Washer
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
Why wont my ewf 1080 electrolux spin
Most likely the washing machine is stuck in Hold mode. Check if you have the spin speed knob at the correct setting.
Manual is available from here
http://www.manualslib.com/manual/616814/Electrolux-Ewf-1080.html#manual
Check the parts and schematics at this site
http://spares.bigwarehouse.com.au/index.php?cPath=64689_77309_77544&sort=2a&page=1
Aug 29, 2014 | Electrolux Washing Machines
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
Jan 20, 2013 | Washing Machines
Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
I need an Electrolux EWF 127410 Instruction Manual in English
http://www.electrolux.co.uk/Support/Manuals/ does not list this model but has an option to enter your details and they will send you a manual.
Jun 06, 2011 | Electrolux Washing Machines
A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Jul 24, 2010 | Electrolux Washing Machines
Electrolux EWF 1495, spin does not work in quick60 cycle
it,ll will be a circuit board fault, probally the motor inverter board there is 3 pcbs in this model.
May 27, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Jan 12, 2010 | Washing Machines
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
Whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Mar 12, 2009 | Electrolux AWF1235 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
