Question about RCA D52W19 52" Rear Projection Television
No power green power light comes on fly back transformer makes a high pitch noise. this happens three times and then nothing. you can wait 5-6 min and do the same thing again. on the PSB-850 CB( i think this is the deflection board) i have a Capacitor that is blown. i want to replace the deflection board but i do not know how to get the HV wire from the flyback transformer out of the HV splitter.
    President:
  • 4,402 Answers
Push down and turn
Posted on Jan 17, 2008
There's an intermittent high pitched noise from sharp aquos lc32 le600e
Sounds like a transformer or choke that has loose windings and they are resonating, you can pull the back and put small amounts of silicone on those components or replace the power board
Dec 19, 2017 | Televison & Video
When i turn on my 42 inch hitachi pd9700 tv it makes a fizzing noise from the back.after 10 mins it gets louder until its like a high pitched whistle.then when i try to turn it off by the remote the...
This problems it the cause by the power supply board.Those transformers on the power supply board is the cause.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 17, 2010 | Hitachi 42PD9700 42 in. Plasma Television
High pitch/humming noise from Frigidaire Refrig.
You have to isolate this problem. It could be one of three things. The compressor, the condenser fan motor or the water valve that feeds the ice maker and wtaer dispenser. Also if the high pitch sound is compared to that of a bird then it is definitely the condenser motor. To isolate the problem take the back cover off. LISTEN FOR THE HIGH PITCHED/HUMMING NOISE! Use a flash light and see if you can tell where it is coming from while it is doing the noise. Dont try this unless you know what your doing. Stop the condenser fan blade with the end of a hard object, but stop it gradually. Dont try this cause you might brake/bend the blade. But if you did and the noise stop then you figured out your problem. If not ythen disconnect the water valve. It has to doulble harness wires attached to it. if problem still exisit then it has to come from the compressor. Unless you have a warranty then theres nothing no one can do except change it. $300-400 job easily.
Mar 27, 2010 | Frigidaire FRS26RLECS Side by Side...
No audio/video
sounds like fly back failure. high voltage transformer
Aug 12, 2009 | RCA 27V514T 27" TV
TV won't turn on even though it starts green, then goes off
Although my tv still does the "turn green and turn off" thing, I simply unplugged and repluggd the tv. After I did that, I pushed the "ON" button on the tv itself, unplugging and replugging the tv until it finally came on. I think the "instant warm-up" switch is going out.
Feb 18, 2009 | iLO 3200 32 in. LCD Television
Wont come on green light comes on three times
Check hori output Transistor if it is shorted set will not come on Part # NTE2324 if it is ok CK second ribbon connector on the deflection board going to board on right. make sure it is in good if it isnt set will make noise and not come on,
Dec 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
Samsung PCL542R Chirping noise
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
