Question about Nabi 2 Disney Edition Tablet
Volume too low
Cannot turn the volume up
Linsay tablet volume for music and movies is too low
It looks like an entry level tablet. It doesn't appear to have Bluetooth. I was going to suggest an external Bluetooth speaker. You can however get powered speakers that would connect to the headphone socket.
http://linsaydigital.com/index.php?productId=32&ref=LINSAY%20F-7XHD
Something like this
Mini Portable Hamburger Speaker For IPod IPhone Tablet Laptop PC MPful...
Nov 15, 2016 | LINSAY Tablets & eReaders
My volume is relly low even wen its at max pleasehelp
I can't figure out what you are asking. Can you rephrase your question? What operating system are you using, Win7? If so, try right-clicking on the "speaker" icon found in the system tray (lower right hand side of screen) and select 'Open Volume Mixer' option. Make sure all settings are not set to minimum. It could be another config setting. Explore other options under the "speaker" icon.
Good Luck.
Jan 23, 2015 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
My tablet sound is low even when i have my volume settings at the max
This may sound silly, bit do you have your tablet in a sleeve or cover? If so, check that the cover is not covering the speaker outlet(s) on the back of the tablet. If it is, a hole or slot cut into the cover over where the speakers are located should fix the problem.
By the way, a quick test to see if this is the proble is to operate the tablet with the cover removed. If the sound is now OK, it's the cover causing the problem. This happens more often than you might think...
Also, some tablet do have really poor audio systems and both low volume and low quality sound. Hopefully your tablet is not one of them.
Jan 01, 2015 | Tablets & eReaders
Low sound can hardly hear it even tho the sound is turned high
Sometimes the app you're using has it's own sound control that overrides the device sound setting. Look in the app for sound settings, eg audiobooks apps often have a separate setting for volume and this is the one that you need to adjust.
Cant hear volume too low
this could be a codec problem or video was record on low sound settings .try checking that your sound is up full right click on sound icon....open volume mixer make sure all slides are up full.
hope this helps
Apr 19, 2014 | Nextbook Premium 7 Capacitive Touch...
Low volume, seems volume button is wired backwards. push on the left side and volume raises
My Android (not an Iolo) has both a touchscreen volume control--as well as a pair of physical volume control sliders--the latter on the right outside edge. I put the tab into a temp car mount: The resulting friction slid the volume down to nil--the the physical sliders, contacting the mount, proved the culprit (despite the touchscreen volume control setting). I proved puzzled at first, cursing the tab.
Mar 17, 2014 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Low volume nextbook premium
there a few. free apps for this using play store the problem is the built in speakers may not do it so it sounds crackly,one fix I saw was using the equalizer and turning up the bass.I have not tried this yet,they recommend headphones hope this helps
Mar 07, 2014 | Nextbook Premium 8 Se Android
Echoing when using facebook video chat
Low down your mic volume and also turn off woofer if it is on.
Oct 27, 2012 | Gateway M285-e Dual Core Touch Screen...
How fix volume
Go to settings, then music then volume limit. Check to see if it is too low if so increase it to a volume that is comfortable. Hope this helps.
Dec 08, 2011 | Apple iPad 64 GB 3G Tablet PC
My Ipad volume is way too low when playing movies. Can you help?
Try adjust the control panel to full volume. If it the volume is still too low to hear movie conversation, put the movie back to computer and use some video tool to set it volume up. I think the pavtube video converter can increase video volume by 400% by converting them.
Oct 11, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Nabi 2 Disney Edition Tablet Logo
91 people viewed this question
Top Nabi Tablets & eReaders Experts
Steve
David Payne
David Payne
jeff5may32
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
