Question about AEG Dryers
Electrolux model mex731cas3
Motor just humms and won't start when start switch is used.
    Habit-Forming:
    New Friend:
  • 186 Answers
Machine needs to be broken down, cleaned and inspected. There is a chance there is something caught in the turbin that circulates air through the machine.
Posted on Dec 04, 2015
2 Suggested Answers
milten1
  • 1304 Answers
SOURCE: WILL NOT START
two possibel reasons for this
1, you have something stuck in the blower moter
look down the lint trap you may just be able to see it
2. your motor is going bad
open the door and hold the door switch with tape or something like it
push the button and try to spin the tumbler while you hear the buzz
if it starts up and the buzz goes away,,,, your motors start wionding is gone and you will need to replace the motor
Posted on Oct 21, 2009
Won`t starts for second load of clothes. just humms?
Does it start after about 1 hr?? Sound like the motor is going bad and over heating. If it starts when it cools off then motor needs replaced.
Mar 22, 2015 | Washing Machines
Won`t start to dry second load of clothes after the first. dryer humms?
If hum is coming from motor and it won't restart until it cools down, it usually means the motor is going bad and overheating. This could also be caused by excessive lint around motor area or blocked vent but usually the motor itself.
Mar 22, 2015 | LG Dryers
Just hums won t start
must be a hummer?
sell it and make big bucks..... and save a fortune in fuel.. LOL
yes, start motor spins (humms) but crank shaft is dead.
bad starter solenoid.
to prove that jump start car, fail, bad starter/solenoid.
acid test is hotwiring the solenoid, ask.
Dec 18, 2013 | Toyota Cars & Trucks
My kenmore washer series70 motor humms
yes there is a capacitor on most washing machine motors on a kenmore series 70 it should be on the right front panel upright leg
Dec 06, 2012 | Washing Machines
My 70 series just humms
What is the complete model number of your unit?
Dec 05, 2012 | Washing Machines
Model SP15921TLNP 1HP pool pump. Only had 1 year. We have had local quick on off power outages in this area. Now Pump does nothing. Using tester have power into the motor. I think may be capacitor but I...
Capacitor should be inside cylindrical cover on motor's side; simplest test is to replace it. If motor humms but won't turn maybe bad capacitor, stuck bearing (turn by hand) or bad/dirty centrifugal switch contact. If no humm at all, may have burnt internal neutral wire.
Jul 08, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
Kenmore series 90 electric dryer does not heat and shuts off after several minutes of use. Heating element is at 9 ohms, spec is 7-11.5 , thermal limit switch was open. I replaced thermal switch and...
Make sure the vent is clear.
Does the motor humm when it starts?
If it humms then the motor is bad. Make sure the rollers are not stuck or that the blower has obstructions inside.
http://www.pdxappliance.com
Feb 27, 2010 | Dryers
Maytag/Amana top-load washer motor humms but fails to start
id start with the start capacitor first. but ive seen a bad pump lock up a unit too. motor switch could be bad if the capacitor does not fix
Jun 24, 2009 | Amana ALW880WH Top Load Washer
Open Questions:
Dryers Logo
81 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an AEG Dryer Expert? Answer questions, earn points and help others
