Question about WEIDERFITNESS.COM Weider Platinum Plus
Weider Platinum Home Gym - Cable Motor Stopped and Controls Blink
When powering up the WPP the crossbow motor stopped then the electronic control panel lights began blinking on and off. Shutting off power and starting again was no help. I followed troubleshooting guide in manual which partially worked (looked like it was going through an electronics system check and LED check). But the remainder of the procedure did not work. I never did get the controls to respond properly or the crossbow motor to restart as manual stated they would.
Is there a master reset sequence I can try, or a fuse to replace, or other solution?
    Problem Solver:
  • 10 Answers
Tammy, check fitnessrepairparts.com
Posted on Jul 15, 2010
My son received an old Weider 8515 weight machine from a relative. The cable was worn and broke. Where would I find a replacement cable?
Posted on Aug 16, 2009
Replace internal cable weider platinum xp 800
This is a tricky job.
I do suggest calling a professional.
Because if you have to ask then explaining is very hard to do
Nov 30, 2013 | Weider PLATINUM XP800 Console
My weider platinum home gym will not adjust weight- the resistance buttons increase and decrease, but the motor will not run
It sounds like the motor is burned out or the connections form the switch, or to the motor are bad. You'll need to troubleshoot with a voltage meter.
Sep 16, 2013 | Exercise & Fitness
Looking for a web site to replace the cable on the Total Gym Weider 2980X stack home gym
Try this..
Customer Service for Retail and QVC Models
For help with all Total Gym retail and QVC models (models other than Total Gym 2000, 3000, XL, XLS and Electra) please contact Customer Service at 1-800-321-9236. // Web Trends Definitions var gDomain="statse.webtrendslive.com"; var gDcsId="dcsupufpe10000s9urugpmzne_2k1h"; var gFpc="WT_FPC"; var gConvert=true; if ((typeof(gConvert)!="undefined")&&gConvert&&(document.cookie.indexOf(gFpc+"=")==-1)&&(document.cookie.indexOf("WTLOPTOUT=")==-1)){ document.write(""); }
// onTarget tag var s_PageName= "fitquestcs.php"; // Quantcast tag _qoptions={qacct:"p-86P2XjTjOrkgc"}; // load JS files at window.onload Event.observe(window, 'load', function() { // onTarget tag // EAC.JS.load('/ontarget.js'); // Quantcast tag EAC.JS.load('http://edge.quantserve.com/quant.js','javascript_tracking'); // Keyword Max tag //EAC.JS.load('http://keywordmax.com/tracking/show.php?id=468164933&blockengines=WS&loc=Homepage'); // Begin SearchForce tracking code for landing page (4.0) EAC.JS.load('http://sftrack.searchforce.net/SFConversionTracking/CTCommon.js','head',{onload:function(){ SFCookie.include(); window.jcexpire = "30"; window.jURLData = "" + window.location.search.substring(1); if((jURLData && jURLData != null && jURLData != "null" && jURLData.length > 0) && jURLData.indexOf("jsid=") > -1) ImageJSLandingProcess(); }}); // Touch Commerce Chat tag EAC.JS.load('https://totalgym.inq.com/chatskins/launch/inqChatLaunch319.js','head',{charset:'utf-8'}); }); if (!navigator.cookieEnabled) document.getElementById('cookieEnabledCheck').style.display = 'block';
Jan 22, 2011 | Total Gym Weider 2980x 214 Lb Stack Home...
Lost weider crossbow assembly manual
how do i set cables for my weider pro multie gym
Aug 08, 2010 | Icon Exercise & Fitness
Learning how to set up the Weider crossbow for different exercises,I have no paperwork for this machine and not sure how to use it..
Go to iconservice.com click on to manual input weider then brand name crossbow and their is 12 manuals to choose from and I found 1 YouTube video about 3.28 mins long more of promo then instructional but it give will you an idea how to use the unit.
May 15, 2010 | Weider Nutrition Weider WEBE8077 Home Gym...
I have a weider crossbow platinum
Hello there, If you go to iconservice.com they have contact information, manuals and just about any other information you may require for your Crossbow.
Fyi the first thing I would check is the power supply itself to be sure it is putting out the correct voltage.
Good Luck! Tim
Jan 29, 2010 | Exercise & Fitness
WEIDER PLATINUM CABLE MOTOR HAS STOPPED WORKING
Hello there. I have seen this problem on a number of occasions. The problem is usually the lower wire harness. One of the wires will break going to a limit switch and disable the motor.
If you would like information on the part you can find it at iconservice.com in the replacement parts section by entering the model number (usually located under the seat) and then locating the lower wire harness. The replacement procedure is rather lengthy! If you do not have patience please have a professional do it for you.
Good Luck! Tim
Jan 11, 2010 | WEIDERFITNESS.COM Weider Platinum Plus
I have a Weider Platinum XP800 Crossbow that will not start.
I had the same problem. Take off the black box at the base and check to see if any of the wires broke lose from the connectors, mine did. One pair of wires was alot shorter than the rest, so when the previous owner disassembled the crossbow he lifted the unit too far before disconnecting the wire connectors thus braking the two wires from the connector. Simply remove the remaining wire bits from the connector with something sharp (unplug machine from the wall). Then take the broken wires and push them down into the connector terminals with a butter knife. The terminals will cut through the wire insulation and make a contact with the wire. Problem solved.
Jun 14, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
WEIDERFITNESS.COM Weider Platinum Plus Logo
1,408 people viewed this question
Top WEIDERFITNESS.COM Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a WEIDERFITNESS.COM Exercise and Fitnes Expert? Answer questions, earn points and help others
