Question about Sharp Televison & Video
How do i tune a sharp ga499wjsb tv - Sharp Televison & Video
Auto tuning digital tv lcd Sharp LC-32LE345X
Maybe your Sharp TV wants you to go back to setup and go through the whole routine again.
Nov 21, 2013 | Sharp Televison & Video
I have a sharp aquos LC32AF3x which was working fine . We have moved and now it will not tune into stations. I have used the same connections on another tv and that tv locates the stations when tuned but...
Your TV has to be able to sense local station signals as part of the tuning process. there may be a problem with the antenna or cable connection.
Jan 05, 2018 | Sharp Televison & Video
I cant tune in my tv its a sharp dv5103h abd i have lost the manual
Dear customer,
Sharp TVs often require you to press the TV Tuning preset key which is a yellow function key.
   Setting Up Your Sharp TV
Turn on your TV.
  1. On your Tune In remote, press TV and release.
  2. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  3. Enter the first three-digit TV code for your Sharp from the list which follows:
    093, 165, 039
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  4. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
U can also refer to the following link for ordering manuals  http://www.aerialsandtv.com/tvservicemanualsmainpage.html
Plz rate this solution..
Apr 09, 2009 | Sharp Televison & Video
How do you tune in a Sharp tv
You need the remote to tune direct. You can find a replacement HERE.
Apr 08, 2009 | Sharp Televison & Video
How do I tune my Sharp TV G0833PE to Foxtel
what is foxtel? is it a cable company? or satelite company?
Jan 07, 2009 | Televison & Video
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SHARP TV CHANNEL LOCK
Probably the best way is to contact SHARP directly. The owner's manual can be downloaded from SHARP's homepage for free.
Sep 16, 2007 | Sharp 25L-S100 25" TV
Sharp Tv, can't tune in channels
Sounds like he accidently put it in parental lock, the remote should have the "key", the user instruction book will have the answer also. Hope this helps
Aug 16, 2007 | Sharp 14U-FM1 14" TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
