-   how can i select the memory (nokia e65) as phone and not the memory card? i'm trying to increase font size of my nokia e65.
-   reyesrudiger
Apr 08, 2009
-   want to increase the font size to different font hoiw to proceed and adjust the font size on the pc
tried abiove procedure but could not suceed-   jamoil
NOKIA SAYS THAT THE FONTS ARE NOT CHANGAABLE THEY ARE WRONG!
There is quite a simple way to change system fonts in the Nokia E65 phone.
The following is how I did it in my E65.
First you have to select the memory as phone NOT the memory card.
Then connect the phone to PC through the standard USB cable. When the phone prompts you, select “Data Transfer” NOT PC Suite”. Once the phone is connected you can view it as a removable drive. First check if a directory named “Fonts” exists.
If it does not exist, just create it in the resources folder. If it already exists, just make a backup copy of it.
Now, go to your PC Fonts directory (usually c:\Windows\Fonts) and do the following:
You can use any TT font I used a font called Baveuse.TTF as the bold I used the Baveuse3D.TTF as my normal font. You have to have (3) three fonts and they have to be renamed to what is below or it won’t work.
Copy Any (True Type you want) font file to:\resources\Fonts\NSSB60.ttf
Copy Any Bold (True Type) font file to:\resources\Fonts\NOSNR60.ttf
Copy again the same normal Bold (TT) font file to:\resources\Fonts\NSTSB60.ttf The (3) Three fonts have to be renamed as above or they wont work!!!
Then just disconnect the phone from USB turn it off. Then restart your phone and put the memory back to the card and you will have the new fonts in place. This is how I did my E65 and it worked ok for me. If the fonts are to big just start over delete the three fonts and use a different font to you find one you like I like the Baveuse.TTF font its personal choice.
