Question about Samsung 1000W 5.1-Ch. 3D / Wi-Fi Blu-ray Home Theater System HT-E5500WZA
Function keys advance on their own
When I try to use AUX it jumps to hdmi 1 then 2 then ipod
  • 3 Answers
Does this happen only when you use the remote control? If yes, remove the battery and return it. If this does not work, there could be bridge if there has been liquid splash on the remote previously. You need to remove the battery of the remote control and try to allow it to dry, it opening it is possible, then gently clean phase and allow to dry before coupling it back. Hope this helps
Posted on Dec 31, 2013
Samsung ht-c653w will not give me any sound at all from my digital audio in or my a/v input. (trying to hook up my ps3) But when I hook up the hdmi, the audio is fine for any dvds I play. think it's...
Have you selected the AUX IN?
AUX2 : Connecting an External Analog Component
Analog signal components such as a VCR.
Connect AUX IN 2 (Audio) on the back of the product to the Audio Out of the external Analog component.
Be sure to match the colors of the connecting jacks.
Press the FUNCTION button to select AUX 2 input.
The mode switches as follows :
DVD/CD ? D.IN ? AUX 1 ? AUX 2 ? USB ? IPOD ? FM.
Jun 05, 2011 | Audio Players & Recorders
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
Cant find aux conection for ipod function pioneer car stereo deh-p6800mp just need help trying to get ipod playing
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing2.gif this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio2.gif and scroll through the sources and make sure it is there.
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
or you can order the direct ipod adapter made by pioneer, which will let you control the ipod directly from the head unit itself. whichever you prefer http://www.google.com/products/catalog?hl=en&source=hp&q=pioneer+ipod&um=1&ie=UTF-8&cid=9877805020289826524&ei=_vPKSpzyKYe4NrzrpPMH&sa=X&oi=product_catalog_result&ct=result&resnum=1#ps-sellers
Oct 06, 2009 | Pioneer DEH-P6800MP CD Player
Aux for ipod
Make sure this is connected to an Aux Input and NOT an output. You did not mention what manufacturer you have for a head unit, so I'll take a guess.
Is is Pioneer? If so, with the radio off, you'll need to either hold down the "source" button or the "func" button. Scroll to the "AUX 1" or "AUX 2" function and then change it from "off" to "on". Then press source and it should be active.
If it is another brand, you'll need to do a similar process of going into the set-up menu and turn on the aux function. This should enable the feature.
Other than that, the operation manual for your radio can be downloaded from the manufacturer's website.
Hope this was helpful.
Sep 28, 2008 | Car Audio & Video
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Cannot get Aux to display after new battery installed in vehicle
This is easy, Press in and hold the function button and the volume dial,.. after the function menu comes up press function again to get to Aux off.. press up to get it to Aux 1 and then press in the volume dial again and youre set!
Jun 23, 2008 | Pioneer Premier DEH-P480MP CD Player
Hooking up an Ipod to my stereo
I'm having the same problem. I pressed the "function" button about 50 times and AUX never showed up.
Jan 06, 2008 | Pioneer DEH-P3700MP CD Player
Finding the AUX button
With the stereo on, hold your Source button to turn the stereo off.
The hold the function button, a menu will appear, press function repeatedly until you see the Aux setting, and you will have an option to enable it with the navigation keys.
Once done press your source button to turn the stereo back on, and then go through the varioud sources and ye shall now find Aux as an additional source ;o)
Dec 05, 2007 | Pioneer DEH-P8200r CD Player
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Samsung 1000W 5.1-Ch. 3D / Wi-Fi Blu-ray Home Theater System HT-E5500WZA Logo
48 people viewed this question
Top Samsung Kitchen Ranges Experts
ray gallant
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
