Question about Weather King 10AJA3601AH Air Conditioner
Is there a reset button?
Worked great last year - won't turn on at all. Breakers are all OK.
I think my model is actually 10AJB36A01
  • jimsmith58 May 20, 2009
    Guru was extremely prompt and accurate. My problem is solved.. He was outstanding!
    Guru:
  • 462 Answers
DO you have 24 Volts at the out door unit from the thermostat?
If so trace these 2 wires down. Both Will eventually go the what we call the contactor. While tracing down these 2 small wires see all the items they go to. You could have a High pressure switch (usually has a manual reset button on it) a low pressure switch, a delay timer and maybe a few other items I cant think of at the moment.
Usually the High pressure switch is the only one that has a manual reset. Where the button is depends on who made the switch. If its a red plastic body type the button will be on 1 end. If its metallic and rectangular it button will be about 1/4 inch long and protruding down 1 side of the rectangular box. Both of these type switches have a copper tube or a screw on mounting that allows the switch to sence the pressure on the out door coil (or if a heat pump it will be on the line on the compressor that goes to the out door coil or to the reversing valve).
If this helps you please giver me an outstdnbding rating and if you need more info please post and I'll get back to you. Thanks for using fixya.
Posted on May 19, 2009
  • Farley Redfield
    Farley Redfield May 19, 2009
    Oh yes if you have a heat pump there will be at least 5 or more wires coming form the inside section.
Wont cool compressor wont kick on
Posted on Aug 05, 2011
Tip
Generator runs great but produces no power
On Thursday last week I had 220 amp outlet being used and a 110 amp outlet being and overloaded the generator. It turned out to be the reset breakers failed to trip and blew the capacitor. The reset breakers I would suggest replacement after 7 years very easy to do on a 5500 Valsi generator 2010 model still running and now producing electric. And of course use only regular gas non Ethanol.
on Aug 19, 2015 | Electrical Supplies
Samsung Charater Not Working!!
There is a simple answer to this and that is to replace the phones digitizer or touch screen and your problem solved.
May 02, 2013 | Cell Phones
There was a power outrage and now my computer won't turn on?
Check the source of power to your computer. Your computer should be plugged into a protection strip. Make sure that the protection strip reset button is reset. If that is ok, check the circuit breakers in the fuse box.
Jan 29, 2013 | Computers & Internet
Reset oreck XML professional
The reset button is power button,look at what it says under cell check button, hold(symbol) button t reset.
Jan 27, 2013 | Oreck XL® Air Purifier
Dryer won't restart breakers ok door switch funtional but when i press srart button just buzzes......... suggestions?
Reach inside and try to turn the drum. If it is stiff you could have a bad roller or support bearing depending on your model. I have all kinds of dryer manuals HERE
and Here
Jul 07, 2012 | Dryers
Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
JVC XV-511 Audio OK with CD but none with DVD
Walks' solution worked for me! Thanks lots! I was about to head to the repair store!
Nov 29, 2007 | JVC XV-511 DVD Player
Weather King 10AJA3601AH Air Conditioner Logo
360 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
