I had to re-install operating system, everything works except the wireless adapter
  • 61 Answers
Hi there, no need to reinstall operating system. You may need to load the driver for the wireless adapter. Whta operating system is running on your computer? If XP, the adapter may use the built in driver for XP. you just need to plug it in and run the install wizard all the way out. Then locate the wireless network connection icon found in the tray near the clock. Right click and select view available wireless network. Select the wireless network you're trying to connect to. If using a pass key supply the correct pass key and once connected, you should be able to go online.
Posted on May 19, 2009
Install drivers device windows xp
That's because wireless protocol "N" wasn't invented when XP was written. Either buy a "G" wireless adapter (which will work with XP) or upgrade your operating system to Vista or 7.
Oct 15, 2013 | Zonet ZEW2546 Pre80211n Wireless Adapter
I had a working Dell computer - accessing the internet through a wireless router - computer became unbearably slow - re-installed Windows XP 2002 SP1 everything's fine except the network adapter that was...
You don't say what make/model of network adapter (NIC), whether it's wired or wireless, or if it was operating under the same service pack level before, so I have to make a lot of assumptions.
Is Windows really not recognizing it (ie: does it have an exclamation mark next to the NIC in device manager?) or is it being recognized by Windows but just cannot connect to the wireless router? If the latter, check your wireless configuration (SSID, WPA key, etc). Since you have WinXP SP1, it could be that there is not a driver for that particular NIC. Later service packs include updated drivers as well as bug and security fixes. Recommend you identify the NIC and if you have the driver disk for it, go into Windows device manager to select a reinstall from that disk. If you don't have it, use another computer to download its driver and after installing it and getting Internet access, you should also download and install the latest SP, which would be SP3.
Feb 18, 2011 | Dell Ethernet Card Network Adapter
Internet connetion isnt there. Everything is installed properly but the wireless adapter wont connect. Do I need to buy an ethernet cord? I need help.
Which operating system are you using?
Are you able to search the wireless signals using it or its not even finding the wireless signals as well?
Feb 13, 2011 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Installed this driver and everything installed ok except it can't aquire network address
Computer not able to acquire the IP address is not an issue with the wireless adapter all-together. Check the device status for this Wireless N Mini USB wireless adapter under the Network Adapter category. It should say: This device is working properly.
If this is the case, you may check for any driver updates with the manufacturer.
Check for any Firewalls like Norton, McAfee, Zonealarm, Comodo, etc. Turn them off or configure them properly.
Update the operating system using Windows Automatic Updates.
On the wireless transmitter, try changing the wireless security type as "WEP" preferably 64-bit WEP with a hexadecimal password.
Finally, if even that doesn't help, try to assign static IP on the wireless network connection by right clicking on Wireless Network Connections and click Properties. Now ensure a tick next to Internet Protocol version 4. Highlight it and click on Properties on this page. Refer to your wireless router or wireless modem vendor to get this assigned.
For further clarifications, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 08, 2010 | EnGenius EUB9707 Wireless N Mini USB...
After i format my lenovo computer i found that everything is ok except for my wireless and bluetooth problem though all the drivers needed are installed. Then i try to take out the wireless card underneath...
Hi. Make sure that all drivers are installed and the wireless card switch is turn on. Try Disabling/Enabling the wireless card by pressing the Fn + F5 key.
Jul 11, 2010 | Lenovo (40Y7026) Wireless Adapter
I have an Asus eeePC with WinXP Pro sp2 installed. One of the driver downloads was Asus update for eeePC. I used it and it updated or replaced the BIOS. I should not have done that. Everything appears...
go to your bios setup find any link relating to your hardware device for wirless lan or network adapter...im not familiar where it is exactly though but im sure the update caused the deviced to turned off or something like disabled..hope that helps..
Nov 29, 2009 | Computers & Internet
Network Adapter cannot start
i think your network adapter has have a damage
i hope i can solve your problem
Aug 25, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
How do i install the 2wire usb wireless adapter without the cd?
Got to:
http://drivers.alege.net/6924/2Wire-80211g-USB-Wireless-Adapter-Driver-Windows-98SE-ME-2000-XP-download.html
and download the free self-extract installer - twwgusb_2.3.1.3.exe
READ the Readme_first.txt and follow the 2-step instruction.
NO NEED FOR A CD!
Aug 06, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Netgear WPN111 RangeMax Wireless USB Adapter won't stay connected
Please let me know about the model number of the wireless router and the operating system installed on the concerned computer.
Aug 04, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
COMPAQ iPAQ Networking 11 Mbps Wireless USB Adapter HNW-200
@river55
make sure the drivers installed then ur good - happened to me
@plante
type ur routers IP in
Jan 14, 2008 | Compaq (243658-001) Wireless Adapter
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
