Question about Canon 15 Pixma Mp620 Premium Compatible Printer Inks
Code error 250.0.0
Scanner error
Error code c-c 152
I think your problem comes from the scanner, try the operation if you have anotherPWB-C when you turn on the machine.
5/16/79 CC151: Error upon startup ROM contents (MSC)
5/16/80 CC152: Error upon startup ROM contents (Scanner)
5/16/81 CC153: Error upon startup ROM contents (PRT)
5/16/82 CC154: Error upon startup ROM contents (PH)
1 Check the ROM version. -
2 Rewrite the firmware. -
3 Replace the Appropriate board.
Apr 25, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
My canon pixma mp 250 will not scan code error shown 2,140,2. find the answer my email id
This could be because the ink cartridges may be empty or been replaced with compatible types.
Solution:
You could try to do a reset by pressing and holding the reset button (red triangle) for 5 seconds. If that does not clear the error then try pressing and holding both reset and maintenance (pliers and screwdriver picture) for over 5 seconds. The flashing error code should change to normal counting display digit 1, and the scanner become usable.
Sep 21, 2011 | Canon PIXMA MP520 InkJet Printer
Canon mp250 error code e16
How to Reset waste ink counter (Error E16)
1. Unplug power and USB cable.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
Hope it helps.
Jun 30, 2011 | Office Equipment & Supplies
Sir machine code 320
this is an laser sync error usually requires new polygon/scanner motor part No B1211876 or may be B2591876 for US> you could try laser sync in service mode go to drum section and you will find laser sync there
Hope this helps
May 11, 2010 | Ricoh Aficio 250 Copier
We have a docucolor 250 and have the error code 016-311. I want to know what it´s means.
May just have a bad cable connection from the scanner to the processor or the scan lamp is bad.
Feb 12, 2010 | Xerox DocuColor 240 All-In-One Laser...
Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
Dec 10, 2009 | Office Equipment & Supplies
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Canon 15 Pixma Mp620 Premium Compatible Printer Inks Logo
32 people viewed this question
old marine
old marine
