Question about Garmin nvi 285W GPS Receiver
GPS OFF when i try to get directions it wont let me get directions it just sayGPS OFF
  • 184 Answers
Check the battery life. does it do that when it is plugged in power?
check the memory space too. if it is ok, then you have to reset the GPS or better still, update the software with the latest version. If it continues to power off, then check the power connection and be sure its not sticky or defective. Cheers!
Posted on May 19, 2009
Inserted a 1G memory card instantly it turned off now wont come back on
try removing the card and connecting the GPS direct to your PC. Download the latest software and reboot the unit. It should be OK.
Sep 17, 2015 | Garmin nuvi 215 GPS Receiver
My plow wont angle or lift
Did you try angling in both directions? If the blade is angled all the way to one side (most likely to the LEFT), it could be that the valves are stuck directing fluid in that specific direction. Check that you are getting power to your "B" solenoid when you are trying to lift the blade, and power to the "C" solenoid when you are trying to angle in one direction but not the other.
Mar 03, 2015 | Cars & Trucks
Line advance wont work
Check these two things first... If dual line both should be wound in same direction. If wont advance maybe the line is wound on spool backwards. Try unwinding and rewind in opposite direction.
Aug 21, 2014 | Ryobi Garden
Was installing a winch on my 2009 prowler 700 xtx hooked positive cable to selanoid winch did not work,hooked direct to battery,works,rig wont start
Where did you ground the winch motor? You need a separate, heavy duty, switch with a relay to transfer the positive side voltage properly... DO NOT ground to the battery..use a clean, free of paint, place to ground. You may have fried the solenoid..do not connect the positive side to the solenoid. Direct connection to the + battery from the relay is good with a good waterproof fuse in line. Sometimes I have seen the "maint. free" batteries die when used "wrong" and still show 13 volts+.
Apr 08, 2014 | Arctic Cat 2009 Prowler 700 H1 EFI XTX 4x4
1490t only shows splash screen
Either the firmware and/or map is corrupted. I repair this problem many times by flashing the unit with proprietary firmware that allows the unit to boot directly to mass storage mode, allowing access to the units files via a PC. I replace the damaged files, then reflash the unit with standard factory firmware.
More info can be found here:
http://www.sharc.net/gps_bootup_repair.htm
- Jim
sharcnet-usa@sharc.net
Oct 06, 2012 | Garmin nuvi 1490T GPS Receiver
ELECTRICAL PROBLEM WITH MODEL 358777 WONT START
try and jump the starter direct then if it cracks you have a bad safety switch or solenoid
Jun 30, 2012 | Garden
1988 johnson trim wont go up or down replaced relays still wont work
Try going directly to the trim pump with 12 volts bypassing the solenoids, go directly to the green and blue wires, disconnect the relays first, see if it works, if it does, your problem is before the motor, if it doesnt your problem could be bad or dirty brushes in the trim pump motor which usually can be fixed on the cheap !
Apr 24, 2012 | Boating
Wont read sd card says no maps
contact me directly, I will try to help, my e-mail: service@gps.pol.pl
Sep 23, 2011 | Goodyear GY-120 Car GPS Receiver
Garmin nvi 285W GPS Receiver Logo
54 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
