Question about Optoma HD70 DLP Projector
Screen is not a true square: One verticle side shorter than other
I have Optoma HD71 PROJECTOR. The image from the projector is not a true rectangle image. The verticle sides are fine and the top horizontal side is also fine . The problem is with the bottom horizontal side. One end is slightly higher than the other (by 2 inches). That makes one verticle side shorter (by 2 inches) than the other. I have tried the V-Keystone button but it does not fix. What could be the problem? And how can I fix it? Thanks Dalip
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
Posted on Jun 09, 2009
I have optima hd71- ceiling mount hooked to hdmi sattelit tv-and samsung home theatre - hd channels give me full screen- normal channels with 16:9 does not - have 2 vertical grey bars -tried all adjus
You're projector is most likely fine. Check your satellite box. Go to the menu and see how its set to display video. It may be trying to up-convert TV signals. Try different adjustments from there to see if you see any change.
Oct 27, 2014 | Optoma HD71 DLP Projector
Verticle flickering bar on left side of picture
Use the "Frequency" menu setting to adjust the unit.
Check and reconfigure the display mode of your graphic card to
make it compatible with the product
Mar 13, 2011 | Optoma EP719 DLP Projector
I have a Optoma EP721. It now projects verticle lines on the screen background. How do you eliminate the verticle lines ?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at www.optoma.co.uk/support.aspx (UK) or http://www.optomausa.com/ (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
Feb 19, 2011 | Optoma EP721 Projector
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
The picture on the screen is not square. one side is not the same length as the other 3.
either you have the keystone feature on, or the light tunnel is collapsing. go into the menu and reset the settings to factory default. if that doesn't help, adjust the keystone through the menu. if no change, replace the light tunnel.
Nov 11, 2009 | Optoma HD71 DLP Projector
Optoma projector image yellowing
Very odd problem. Depending on the hours of the projector it could have some glass in it that over heated. Contact Optoma directly, my guess is they will work with you.. good luck
Apr 06, 2008 | Optoma H30 Multimedia Projector
Lcd proctor image
Disconnect the computer and then run projector if it still comes then service your projector.
Viren
Sep 11, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
Optoma HD70 DLP Projector Logo
235 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
