Question about Hoover Dishwashers
Our hoover DDY068TB dishwasher has suddenly started to sound a shrill beeping alarm almost immediately a wash cycle starts. I have done all the usual checks but have found nothing obvious. Have also tried running a different programme but alarm still sounds! Any suggestions please?
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Dishwasher beep twice but dont start washing
Replace door switch
Posted on Jan 01, 2009
  • 423 Answers
SOURCE: Whirlpool Dishwasher,serial number 330251002448 wont stop beeping
The main controller appears to be very confused or failed.
To test, fully remove power from the diswasher for at least 90 seconds. Power back on and test. If the same behaviour is seen, the controller card has almost certainly failed. A service call is the next step to repair.
If you reply, please include the model number of your Whirlpool Dishwasher. Good Luck!
Posted on Mar 31, 2009
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
Why Does Fault Alarm Beep at End of Cycle?
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Mar 10, 2014 | Haier HDP18PA Stainless Steel...
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Dd603 stops mid cycle with no beeps or alarms
Please check if this happens with the short rinse cycle as well.
Also when the fast cycle stops, check if the water is cold at room temperature. Normally water temperature for wash cycles should be at leat 40deg C.
May 04, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
I have a hoover dishwasher and it starts pre wash cycle then wash light comes on and it beeps and stops
THE PROBLEM IS THE LITRE-COUNTER SWITCH AND IF YOU CUT THE PLUG OFF, SOLDER THE WIRES AND SEAL, IT WILL WORK AGAIN NO PROBLEM, ITS COTACTS THAT GET MOISTURE ON THEM. EVERYBODY THINKS ITS PCB OR PRESSURE SW BUT ITS DEFO NOT. I KNOW BECAUSE I WAS A HOOVER ENGINEER.
May 23, 2010 | Dishwashers
HOOVER HOD6615 DISHWASHER CONTINUAL BEEPING AFTER INITIAL RINSE & REFUSES TO PROCEED TO WASH CYCLE WHATS THE PROBLEM?
This could be a safety trigger due to bottom water leak. A anti flood device (polystireen float and micro switch) that switches washer in shut off mode and does not continue until the water leak (pipe or hose clamp) that causes the float to trigger the device. Check the bottom of the washer for traces of water and rectify any leak before the washer will continue.
Jun 01, 2010 | Hoover 24 in. HD83M Free-standing...
You may have a problem with the control board and needs to addressed by a qualified LG technician.
Mar 15, 2008 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
