Question about HP LaserJet 2100 Printer
Images blacked out and jibberish across the page
When I print some of the images are completely black and numbers with other jibberish print across the page.
    Genius:
  • 1,605 Answers
Posted on May 19, 2009
Bizhub C451 printing black smudges across page
replace the black image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 21, 2013 | Konica Minolta Bizhub C451...
My canon irc 5185 double image in black images. any advice
Print Black images with any color piece (ex. page with black text and one red letter in up-right corner) 40-50 pages in one job.
Are you see a double black image?
No: Fuser trouble on high-speed.
Yes: Replace the Drum Unit (Black).
Sep 10, 2013 | Canon irc5185i
All pages print completely Black
completely black print outs indicate the drum needs to be replaced. If you are not familiar with this the drum is the part in the printer that transfers the image to the paper using the toner. It has a coating on it that reacts with the laser to produce the charged image that attracts the toner but when the coating is used or worn out it basically puts an "image" across the entire page so you get a black page. The part number you need to get is DR-250 and they are available from Office Depot or other toner supply stores.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 09, 2011 | Brother IntelliFAX 2800 Laser Fax
I have a pinnacle Pro 901. How do I print in black & white only?
Hello, try this: Start Menu, > Printers and Faxes> then right-click on your printer. Move the pointer down to 'Printing Preferences' and click the 'Advanced' tab. There you will (should!) see 'print in greyscale' . Select this then click 'Apply' then 'OK' at the bottom of the page.
Regards,
nicam49
Dec 01, 2010 | Lexmark X2250 All-In-One InkJet Printer
It prints a complete black page, without any images or text. Even at the test page!!!. Any idea as to what can be done?
I think the ribbon or printer head need to be change since it prints a complete black page, if it is a blank page it prints, i would have said the toner ink is low in the cartridge or finished but since it is a black page it needs replacement.
I suggest you get a technician to help fix it.
I wish you best of luck
Dec 22, 2009 | Samsung CLX2160 Multifunction Color Laser...
Can I fix this stuff without a service call?
black spots can also be caused by drum...
developer normally will cause blur print due to developer uneven or dirty (dust)...
Apr 17, 2009 | Office Equipment & Supplies
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Printing black shaded on complete page
Problem is usually a dirty charge corona wire. There is a cleaner on the drum unit, slide this across and back 2 or 3 times. If not, then the corona wire itself is missing or broken, change drum.
Feb 19, 2008 | Brother IntelliFax-2820 Laser Fax
Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
HP LaserJet 2100 Printer Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
