Question about Vehicle Parts & Accessories
Stinger 310 alarm
Had to recharge leisure battery,when put back on caravan alarm would not work off fob.
SOURCE: changed battery alarm won't turn off engine starts fob opens doors
if it is a aftermarket alarm, get rid of the alarm, or unlock and lock door w/ key am alarms are a problem when they go awry
Posted on Oct 12, 2008
  • 224 Answers
SOURCE: Mercedes CLK 320 '03 Key fob wont work
you will need to reprogram system
Posted on Aug 21, 2009
  • 19 Answers
SOURCE: Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Posted on Aug 28, 2009
  • 19 Answers
SOURCE: stinger xt malfunction
It's a bad battery, the person that sold you that light may have sold you an old flashlight. Every strealight battery has a manufactured date code, four digit on most. Check that out and send it for evaluation before you go ahead and purchase parts you may not even need. The switches are covered under a lifetime warranty just so you know ;)
  • 10 Answers
SOURCE: alarm went off and key fob quit working
start the car. if that dose not work remove ground form battery then after it stops put ground back on that will reset the alarm.
Posted on Jan 28, 2010
Testimonial: "started the car, shut it off and the alarm quit. But now none of the features work on my key fob."
Fob still won't work after new battery and nothing wrong with the contact inside, do not hae original code for the Kia sportage 1998 so what is the next best thing ,to do?
When replacing the key fob battery there is no reprogramming required! If the key fob was working prior to the battery replacement then it would point to the contacts not being correct! Remove key fob battery and start again!
Dec 31, 2014 | 1998 Kia Sportage
Siren works, but no power to instrument after recharging battery. Nothing changed on the bike, was just sitting all winter.
There should be a small fuse box near the battery with probably three fuses inside. Have you checked those?
Mar 15, 2014 | Harley Davidson Motorcycles
Deactivate alarm
change the battery in your fob. check the power in your battery may need a recharge.
Dec 20, 2013 | 2001 Mercedes-Benz C-Class
1996 dodge grand caravan le key fob doesn't work, batteries are good. Can I need to sync it or reset it?
I put a new battery in the key fob for a 2008 Dodge Grand Caravan, and, at first, it still didn't work. Took it to the Dodge Dealer, who said the fob was dead. NOT SO! My husband put a little piece of cardboard on top of the battery so the battery contact was improved, and the fob works fine now.
Aug 04, 2010 | 1996 Dodge Caravan
Alarm went off and key fob quit working
Jan 28, 2010 | 2009 Dodge Grand Caravan
Cannot reset alarm on 98 dodge caravan and vehicle will not start
pop hood open, lock all doors, disconnect battery for about 3min, reconnect battery & unlock drivers door with key.. this should dissable the alarm. replace battery in fob.
Nov 05, 2009 | 1998 Dodge Caravan
After recharging battery on my 1992 Mercedes e300 24V W124 the alarm fob does not reset the alarm and the car is steanded on the drive. I cannot isolate the alarm unit as the Security key foir it is...
Hi, Sounds like you removed the battery to re-charge this then needs to have the computer system re-set before anything will work back to normal. Hopefully your nearest dealer may be able to send a mechanic out to try & re-set the computer. Should you ever have battery problem next time re-charge whilst battery is still in car with the connectors still attached. Please leave me feedback, Malcolm Campbell.
Sep 23, 2017 | 1992 Mercedes-Benz Mercedes Benz 300 Class
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
Recharged battery's, tried to install them, alarm keeps going off
hook up battery and press alarm button on the key fob or just insert key and start truck alarm should shut of on its own
May 17, 2009 | 2005 Ford F 350 Super Duty
Both fobs won't work, i cannot even start the car even with the key because i cannot turn off the car alarm, any ideas what wrong and what i can do?
Hi, i had this problem with my 96 model.. i let the battery go flat, then recharged it.
Although disconnecting the battery my work.
Assuming that the batteries dont need replacing in the fobs.
Jul 23, 2008 | Hyundai Tiburon Cars & Trucks
Vehicle Parts & Accessories Logo
215 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
