Question about Eureka 59 Copper Head Plus Handheld Vacuum
Need tubing for Electrolux copperhead plus vacuum
Need new hose for Electrolux copperhead plus small vacuum cleaner
Need an Electrolux agent in Alberton, SA. Need rubber seal for my vacume cleaner
picture is of the v cleaner unit with that model number
cant find a listing that hose seal as such
the hose with the seal as a whole.. is now discontinued
try looking for a used unit or improvise
Jun 18, 2016 | Electrolux Vacuums
Where is the CVA located in the Electrolux Epic 6500SR?
You need to replace the control valve. It's inside the canister under the dirt cup. If you want it done by a professional, call your local authorized Aeurus dealer.
Jun 28, 2015 | Electrolux Vacuums
Electrolux VACUMM CLEANER LITE II
get new bag filter , empty dirt out to garbage bag , clean hose .
Dec 26, 2013 | Vacuums
Electrolux Epic 6500 Vacuum - Suction stops when hose is attached
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial.
You can ship the vacuum to http://evacuumstore.com/ and they can reapir it for you.
Mar 28, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
I have a new electrolux el7025a-r and it keeps cutting off while I am vacuuming. I am using the small powerhead on hard floors and I have checked the hoses for blockages and the bag is new. I can not...
The wands are notorious for going out on that unit. One or both probably need to be replaced. Try to get it done under warranty if you still have the receipt, but they shouldn't cost you too much if you can't.
Good Luck
Dec 01, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuum hose replace electrolux how to
YOU DON'T SAY IF YOU HAVE THE NEWER HOSE OR THE CLASSIC ONE WITH THE STEEL TIP (BETTER DESIGN). IF IT'S THE LATTER UN-SCREW THE SCREW CLOSEST TO THE STEEL TIP,TAKE A SMALL SCREW DRIVER AND LIFT THE THE PIECE OF PLASTIC THAT WAS SCREWED DOWN JUST ENOUGH TO SLIP THE HOSE OUT.
WHAT YOU'LL BE FACED WITH IS SOMETHING I WOULDN'T SUGGEST CUTTING.
IT MAY BE MORE PRACTICAL BUYING A NEW HOSE. AN ELECTROLUX WILL LAST FOREVER,BUT YOU DO HAVE TO REPLACE THINGS LIKE THE COMBO DUST/UPHULSTRY ATTACHMENT. THE HOSE IS PROBABLY THE FIRST THING YOU WOULD NEED TO REPLACE BECAUSE OF AIR LEAKS. I'VE HAD MY OLYMPIA ONE FOR 27 YEARS AND HAD TO REPLACE THE HOSE ABOUT 10 YEARS AGO. YOUR CHOICE.
Nov 08, 2007 | Electrolux Centralux Vacuum
Vacuums Logo
23 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
