Question about Okia / 450-Watt / ATX / 80mm Fan / 20/24-Pin / Power Supply (OKIA450ATX) Power Supply
No power to motherboard
No power to motherboarb,new build okia 450 ps
  • 2 more comments
  • whizlee44 May 19, 2009
    new build,no power to mb,checked all plug ins and all ok,no power at all-thanks
    on off switch is on,no lights are on and i do not have a meter-thanks
  • Frank Zhang
    Frank Zhang May 11, 2010
    do you check the new power on/off switch to on?
    the motherboard has geen lights on or off?
    do you have meter?
  • Frank Zhang
    you mean "no power to motherboarb,after change a new okia 450 ps"? any lights show on destop motherboard?
    Problem Solver:
  • 11 Answers
Could be one of these:
1. Lead Fuse could of blone
2. Fan broken
3. Insted of the power, it could be your motherboard
4. THE WHOLE THING
Im sure your get it fixed soon and i hope me telling you what it could be has helped you.
DigicalJAI
Posted on May 19, 2009
I have a Okia 420ATX power supply. I had it
Based on the additional information that the power supply fan turns on for a few seconds and then goes off indicates to me you have a motherboard or processor problem. I would have a service center check the computer for you.
Feb 03, 2010 | Okia 420w UL Approved ATX Computer Power...
Friends custom-build PC has no power
Seems reasonable. Take the motherboard out of the case,  first to see if it will work outside of the case. Sometimes boards short to the ground due to a screw or other metal getting between them and the case. Try to run it with as little hardware hooked up as possible. You don't even need a hard drive to post the BIOS.
Mar 12, 2009 | Okia 420w UL Approved ATX Computer Power...
I have a okia 500atx power supply. When I attempt to turn on the computer, it will stay up for about 3 seconds then turn off. is the power supply the problem?
CHECK THE FAN REMOVE ANY DUST AND SPIN THE FAN PLUG IT IN AND TURN IT ON IF SAME PROBLEM THAN THE FAN IS BAD IN THE POWER SUPPLY AND YOU NEED A NEW POWER SUPPLY TAKE IT WITH YOU WHEN YOU GO TO THE COMPTER STORE FOR A NEW ONE
CANDYMANGANDY
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
Power Reaching the MB but NOT reaching the cpu fan
Either replace the line to the fan (or get a new fan with a longer cord )or leave the side door of your CPU off a bit and maybe put a fan beside it.
Jan 06, 2009 | ASUS P5PE-VM Motherboard
My computer turns on but wont turn hdd all the way on it starts then clicks and stops goes to a black screen. and there is a smell coming from the computer. i put the hdd in another tower and it worked.....
If you have a standard atx case then any standard atx power supply should work. Yes you can upgrade to one with more wattage as long as it has all the connectors you need. Hope this helps.
Dec 24, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Pc will not power up
Swimmie
to chack ur power supply open all connector from system board and drive. then conect power cable with powr supply and powr on ur wall outlet switch. than take mother board connector find green color wire and take a small pice of coper wire and connect it with this green wire and a black wire. then chack smps fan is moveing or not if it's moveing then ur smps OK.
Jun 27, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
How do I replace atx power supply?
yo dawg just do like buy a new connector and stuff you know what i mean dawg
Apr 30, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Soldered in new fuse, blew it right away...whats a good upgrade?
A new power supply will fix your problem, and when the fuse blows do not replace it. It blows to protect your computer. please replace with a new power supply.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Oct 28, 2007 | Okia / 450-Watt / ATX / 80mm Fan /...
Power Supply Warrenty
I couldn?t find a web site for Okia either; however, I did note that the venders that sold them usually guaranteed them for one year themselves. I would at least try that route, that and not buy Okia power supplies. There are lots of stories and physical examinations of how poorly they are designed and manufactured.
Sep 19, 2006 | Okia / 450-Watt / ATX / 80mm Fan /...
Okia / 450-Watt / ATX / 80mm Fan / 20/24-Pin / Power Supply (OKIA450ATX) Power Supply Logo
417 people viewed this question
Top Okia Computers & Internet Experts
David Payne
David Payne
Are you an Okia Computer and Internet Expert? Answer questions, earn points and help others
