Question about Zanussi Ovens
Double oven zanussi zdq695x replace fan element
Bottom oven fan element not working
SOURCE: Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Posted on May 15, 2008
  • 1462 Answers
SOURCE: ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Posted on Oct 01, 2008
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
apart4u
  • 213 Answers
SOURCE: Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
Posted on May 27, 2010
barkencoa
  • 3463 Answers
SOURCE: my neff fan oven keeps blowing it element is there
It is quite common for neff elements to fail, make sure you have fitted the correct wattage element to it, as there are more than 1 element that will fit it.
Posted on Nov 12, 2010
I have a Zanussi ZHQ575 X Double oven, the main oven will not work when I select the Fan Oven setting. I have tried a new selector switch but it still will not work on this setting. The fan comes on but...
I have the same problem.... It's not the element gents, please read the question again... the oven heats up on the other settings it's just when you select fan oven (the most popular) I too have tried replacing the selector switch with no luck. Really need a wiring diagram.
Apr 14, 2012 | Zanussi ZHQ575 Electric Double Oven
Fan oven not heating up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
I have a ZDF20X double oven and the main bottom oven is not heating, The fan and light are working but it is not heating. HOw do I repair this - is it an element and how do i replace ? Thanks v much.
Most likely it is a faulty oven heating element.
You will need to replace the element.
Usually the element is a circular shape which is situated near the fan, normally you will need to remove the back of the oven, Switch off the power at the wall first, locate the element and remove the fixing screws and electrical connections then fit the new element and reconnect.
Only attempt this replacement if you are confident to do so and have a basic electrical and mechanical knowledge.
Dec 11, 2010 | Zanussi ZDF490 Electric Double Oven
The bottom oven dosen't heat up yet the fan and the light still works. The model is Zanussi ZU270F.
You need to replace the oven element, located behind a removeable panel at the rear of the oven compartment.
Aug 07, 2010 | Zanussi ZHF470 Electric Double Oven
May 14, 2010 | Zanussi ZDQ495 Electric Double Oven
The bottom oven wont come on
If it is a fan assisted oven, and the fan is working, and it is an electrically heated oven, then you need to replace the oven element, this is located at the rear of the oven, behind a removeable cover.
Hope this helps.
Dec 25, 2009 | Zanussi ZDQ495 Electric Double Oven
Zanussi double oven ZDQ895 top of the oen is hot but oven will not come to temp bottom part of oven feels cool (fan oven)
If the fan is working o/k, then you need to fit a new oven element located behind rear cover of oven compartment.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZDQ895 Electric Double Oven
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
32 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
