Question about Canon ImageCLASS MF4450 - multifunction fax / copier / printer / scanner B/W
Error light how do you reset it - Canon ImageCLASS MF4450 - multifunction fax / copier / printer / scanner B/W
How do i reset mil light
If you have a warning light on the dashboard - you need to have somebody read the error codes.
The hand-held (OBD11) scanner used for reading error codes can also reset any 'check engine'/warning light
Apr 16, 2017 | Cars & Trucks
How can I reset the check charging system warning light on my 2005 mustang
You can use an OBD2 Code Reader. Besides reading codes, it also has an option for resetting all errors. You can get one on Amazon for under $20 and it plugs in under the dash. It's useful to have so you can see error codes before taking for repairs. If you reset the error and the light comes back on, your problem hasn't been fixed.
Oct 28, 2014 | 2005 Ford Mustang
Red light flashing
The red light is indication there is an error. Reset does not solve the problem. First solve the problem, like close all doors, or replace cartridges, then try to reset by switching off and unplug from the mains. Then reinsert the mains plug and switch on again.
If the red light comes back, you did not solve the problem. Read the manual, or give more details, so we can help.
Jul 18, 2014 | HP LaserJet 2550L Printer
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
How do I get rid of the Service Now light on my display of my 2006 Passat?
Obtain error code reader and reset error codes stored on cars computer and the light will reset however if problem is not fixed the light will just re-appear.
Oct 01, 2010 | 2006 Volkswagen Passat
How to reset the check engine light on Kymco 500
You will need a Engine error code reader and will need to read error codes listed and erase all error codes which will reset the bike check engine light.
Jun 21, 2010 | 2005 Kymco Xciting 500
E5 light
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 25, 2009 | Canon PIXMA MP150 All-In-One InkJet...
1720dn error light will not reset
Follow this link to a previous FixYa post about this error and the suggested solution.
Feb 23, 2009 | Dell 1720dn Laser Printer
My MP160 has an error code E5 and nothing I do will move it
I think you may have answered your own question.
Here is a list of error codes for your printer, as you can see the code E5, means the cartridge is not installed properly or un-supported.
I would remove cartridge, check slot for debris, clean contacts on cartridge, re-seat cartridge and then try again. If all fails then try a new cartridge, as the other one could be faulty.
If you still have no joy, you probably have a faulty print head unit.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Feb 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon ImageCLASS MF4450 - multifunction  fax / copier / printer / scanner   B/W Logo
35 people viewed this question
old marine
old marine
