Question about Eddie Bauer 3-In-1 with Latch
Does the buckle between their legs come out?
I am taking the car seat apart to be a booster seat. Does the buckle that goes between their legs come out too? If so how?
    Problem Solver:
  • 6 Answers
Mine, I have to remove the base first and then you can remove the strap and move it to another slot, or to clean
Posted on Jun 15, 2009
  • 20 Answers
Yes it will come out. Turn the seat upside down and where the latch mechanism is you should see the metal/plastic piece that attaches to the ******** the mechanism. Pull this down and turn sideways and push through slot and out the top.
Posted on May 20, 2009
My seat belt light is on when i have the seat belt on in toyota camry 1995
sensor may be stuck inside your seatbelt. spray a lube inside it and put it together and take it apart 5 or 6 times just to get it to loosen. do this to the passenger side as well. if this doesnt work then some cars have a sensor built into the seat that tells the car you have a passenger that isnt buckled. its possible that this sensor is stuck. should be located under seat but can be checked by simply buckling the passenger seat belt and seeing if the light goes out.
Aug 22, 2010 | Toyota Camry Cars & Trucks
Tip
Middle seat belt buckle tip for booster seats, car seats, and large humans.
In trying to fit a booster seat into my 2004 Honda CR-V, I realized that the CRV has the belt buckle in the middle of the seat. This is a big problem for someone using a child seat in the middle seat as the buckle receptacle is completely covered by the booster seat. I thought about buying an extender but realized it wouldn't completely solve the problem. After much thought I came to the conclusion that the buckle receptacle could be moved to a new location without compromising any safety of the belt. I first pulled the buckle receptacle all the way out and then cut the fabric to enlarge the hole from which it protrudes from the seat. Then I pushed it through the hole and back into the seat with the head pointing towards the window and outer edge of the seat. After flipping the window seat out of the way I was able to peel the fabric away from the bottom edge of the middle seat enough to reach in and retrieve the belt receptacle. It was a little tight but I was able to buckle the belt and use the seat belt to pull the receptacle through this new "hole" and VOLIA the belt receptacle is now in a better position to the side of the middle seat. You can now used a booster or car seat or put a fully grown human in this seat and buckle with ease.
on May 20, 2015 | Cars & Trucks
How do you convert it from a car seat to a booster seat?
Take the base off if it has one, either clips, screws, or a metal rod holding it on. Take the belts out. They should slide off the clip at the back of the seat, then unthread belts from buckles. The buckle/strap between the legs usually has a metal keeper below the seat. To remove you need to bend/twist the keeper until you can push it UP through the seat and remove the belt/strap. It is now a booster seat for use with a lap/shoulder belt in the car. Store all the parts you removed in a ziploc bag for when your child outgrows it so it can be reused.
Dec 08, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Washed and need to put buckles back together
Always make drawing and notes of any componentry no matter hw suimple before you take it apart.
Imagine the dimensions of the baby/child in the seat to coordinate the right lengths of buckle hasp sections to required to the buckle tongues [we can term them].
Sep 19, 2009 | Evenflo Big Kid Booster Car Seat - Napa
I am trying to take the cover off the eddie bauer 3 in 1 to wash it. How do you get it apart from the buckle/latch that goes between their legs? It seems to be too big to go through that hole without...
Unbolt the seat from the floor of the truck... turn it upsidedown over a table or some such and the you will see the hog rings that hold the cover to the foam and bottom frame...
Jun 14, 2009 | Eddie Bauer Deluxe High Back Booster...
I cant take the seat belt off to wash it!
Start from the back take them of the little metal things then slot them trough front and take the chest buckle off,the croch buckle should come of easy,look under the seat pad.
Apr 29, 2009 | Eddie Bauer 31447 Booster Car Seat - Sage
Cosco booster seat (Summit)
turn the seat so you are looking at the bottom, insert the strap- one end on each side- turn the seat in an upright possition facing you, put the buckle pieces on appropriate side, attatch the center piece- at the chest- insert the strap into the appropriate slot- the adjustments- now turn the seat so you are looking at the rear of it, attatch the metal retainer.
Nov 25, 2008 | Cosco High Back Booster 22-200 /22-207
Booster seat
Converting the seat to a booster: (Alpha Omega Elite Deluxe 2004 version, Eddie Bauer)
After all said and done, the base can probably be left on, it helps to recline the chair when the child is asleep. If you want to leave it out, the manual says the base can be removed for narrow vehicle seats or airline use. Locate the center bar at the bottom of the seat, push the tab at the end of the bar and pull the bar out. The seat can then be separated from the base. The seat has a "kickstand" that can be pulled out to sit the seat upright. Put the bar back in the base so you don't lose it.
To remove the harness, remove the base first. Then from the back of the seat, unfasten the harness from the harness bracket. Store the bracket by looping it behind and around the back spine of the shell. You can unthread the harness from that point and pull it out. From the bottom of the seat, locate the buckle's metal clip. Insert the clip up through the shell and pad, from the front pull the buckle free from the shell. Lock latch plates into buckle for safekeeping.
Once the seat is converted to adult straps don't use the latch system; hook the hooks together to keep it from swinging around, and place the top anchorage strap behind the seat with the anchor hook under the seat.
Nov 09, 2007 | Eddie Bauer 3-In-1 with Latch
Booster
Remove straps and belt across the lap!
Nov 04, 2007 | Eddie Bauer Deluxe High Back Booster...
Eddie Bauer 3-In-1 with Latch Logo
399 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
