Question about Maytag Washing Machines
Shakes and makes a loud noise - imbalanced
The maytag washer LAT9416AAEis very imbalanced. think the legs need replacement. cant even them up - some parts don't move etc.
  • bhkaplowitz May 20, 2009
    will check that . thanks for the quick response,
Hi.....
Im not an expert, but i used to work for comet electicals. I have come across this problem a few times, and most times the problem was caused by the transitbar/ bolts not being removed on instalation. These can be located at the rear of your machine.
Hope this help, Graham
Posted on May 20, 2009
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Recently, my Maytag Centennial washer is incredibly loud even with very small loads. This happens during the spin cycle. It almost sounds like a truck
Need new shaft bearing. Seals kit .
I've repaired lots of these. Bearing tool is required. Part W10435302 tool W10447783
Tilt washer back look around the motor. Big piece under tub. If you see mud or rust leaking out of motor you should replace this soon.
Dec 07, 2014 | Maytag Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Why does the machine shake a lot on the spin cycle
That usually happens if the load is imbalanced. If you can move the clothes around in the drum so they are more evenly distributed, it shouldn't shake as much.
Jul 14, 2011 | Maytag PAV2300 Top Load Washer
Washer makes loud noise (seemingly unbalanced) while spinning
Suggest making sure all four (4) screw leg adjusters are set correctly i.e. does it wobble if you shake like a "pin ball machine", when not in use? If yes, adjust the screw legs in each corner. To ensure the machine is sitting level and not able to shake... God Luck
Apr 21, 2011 | Kenmore Elite HE5t Washer
Basket rocks loudly during spin cycle. Does it on every load so I don't think it is a balance problem.
i just got a used whirlpool washer and as soon as it went on the spin cycle it started shaking bad! i adjusted the legs and moved the clothes around evenly! still doing it?? i would like some advice please!!!!!!!!!!
Mar 13, 2010 | Maytag Washing Machines
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Maytag atlantis washer making loud grinding noise
The belt are tear and slap to the near obtacle need to replace /
The water magnetic valve are leaking ned to replace /the coil open or valve rusted.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
