Question about Proscan PSVR70 VCR
Proscan vcr psvr70
when i set the vcr for timer recordings i end upwith a blue screen, no audio, no picture, however if i just push record when i am watching t.v i get playback? i need help please.
  • 3 Answers
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to sounds like the vcr is getting the channels from the box and not the will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Posted on Mar 01, 2010
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
• After timer recording is completed, the VCR turns off
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
Press SET –/+ to select one of
the program lines, then press
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
Aug 28, 2010 | JVC Televison & Video
I have sound but no picture on the screen.. What did i do wrong
Hello sir, hi, please check the video cable. If you are using the three color audio/video cable, the yellow one goes to the yellow input of the TV to the yellow output of the DVD recorder. Then check the TVs audio video settings, the TV should be in the video channel, if there are several video channel, check where the video is coming in. Make sure that the yellow cable is good. you can swap several cables to check.
If your TV is component input, put the red green and blue wires to their respective color port, one end is on the DVD recorder, and the other on the TV. make sure your cables are good. Do the same thing with the S-video and HDMI cable. if your TV has this.
Nov 21, 2009 | Daewoo DVRS05 DVD Recorder/VCR
Doesn't give me the option to change the channel when timer recording
If you are recording something on the VCR, it won't let you change the channel. If not, you need to make sure the RC is set to the vcr in question (mine has VCR1 and VCR2)
You can set it up the way I've done for years...put cable line into VCR first, the VCR to then can watch and record 2 separate channels.
May 09, 2009 | Proscan PSVR73 VHS VCR
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Vcr Samsumg Vr8460
1. Is the VCR coming on in the timed mode and recording? Make an experiment- set up a timed record for just a few minutes in advance. Have a tape in the machine- then wait a few minutes & see if it indeed comes on and records. This should for sure help you diagnose your problem.
Note: When a timed record is set up, some VCRs must be turned off, or a particular button pushed to activate the timed record mode, where it will wait for the specified time and come on by itself..
2. Video source set correctly? If all you get is a blue screen, or a moment of snow, then the timed recording is happening, but there is no signal present.
Jun 17, 2008 | Televison & Video
ProScan PSVR70 VCR
Sounds like the VCR is not set on an "external source" but rather "tuner". I believe that will fix this problem...accordianman
Feb 11, 2008 | Televison & Video
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
Jan 24, 2008 | GE VG4054 VCR
Cancelling a Timer Recording
Hi , to cancel just push the record push button .
Jan 19, 2008 | JVC HR-A592U S-VHS VCR
Set a timed recording
Do you have your operation manual? It will tell you how to set up a timed recording. Recording options are set via the remote. Look for an option as "Scheduled recording" or similiar. Date, start & end time, channel, recording speed are all set. If you are missing your manual do a google search with your model number. A quick look at the Samsung website was not fruitful.
Jun 02, 2007 | Samsung VR3607 VHS VCR
Televison & Video Logo
118 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
