Question about Canon Office Equipment & Supplies
Fixing "error" message on MP20DH adding machine
Rec'd error message that I had the Zeus virus and I should call a 1-844 # to fix. Is this a scam?
Possibly not infected with that virus but likely infected with ad-ware that is producing those messages. Either way you need to clean the machine. Google the message you receive to look for possible fixes, or get qualified help.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 14, 2016 | Apple Ipad I-pad
Tip
3 Quick Solutions to Repair Juno Webmail Script Error message
If you have an Ad-blocker or a popup blocker installed on your computer system, you may get many script error messages while connecting with the Juno Webmail. You can prevent these mistakes from encountering by configuring the pop-blockers / ad-blockers correctly. If you're often getting a Script error message whenever try to start Juno or log into the webmail account, then you will require configuring the ad-blocker programs to operate with Juno webmail; otherwise, you may face the Juno sign in problem. There are three methods to do that:
    1.Add Juno Mail to the exclusion list of your ad-blocker
    2.Set up the ad-blocker to enable banner ads
    3.Disable the filtering feature in the ad-blocking program If you're using the AdSubtract tool, you should follow the instructions given below. In the case of any other pop-up blocking or ad-blocking software, refer to the documentation of your blocker tool for the accurate guide on configuring the software to enable ads from Juno Mail. You can get connected to the Juno webmail support experts and solve these error messages in a proper manner.
    Solution 1 - Insert the Juno Webmail to the Bypass Site list
    If you want to add the Juno website into an exclusion list, right-click anywhere on the web page and choose the 'AdSubtract: Bypass Site' option. You may require repeating this procedure on other Juno web pages on which you get the script error messages. On the other hand, speak with the Juno professionals to repair your email account issues.
    Solution 2: Configure AdSubtract to enable banner ads
    This solution will fix the script error messages that can prevent you from accessing your Juno email account, but will also cause in other banner advertisements showing on other websites you access.Here's how to setup AdSubtract software to allow banner ads.
      1.Launch the AdSubtract program and click on the 'Block' icon.
      2.Deselect the Banner Ads field from the selection on the left.
      3.Click the 'OK' button to save and apply the changes. If this workaround doesn't work and you're still getting the script error messages, then either you can get in touch with Juno customer care executives or go to the next.
      Solution 3: Disable AdSubtract tool filtering
      This workaround not only resolves the script error messages for the Juno webmail site but also causes in disabling all of the AdSubtract's filtering efficiently.
        1.Launch the AdSubtract tool.
        2.On the main dialog window, click on the 'Disable Filtering' option under the 'Ad Blocking' section.
        3.Click the 'OK' button to save and apply settings. However, if you still have any kinds of technical issues with your Juno email account, or continue to face the script error even after attempting all these solutions, or any further queries, it's highly recommended to call on the Juno webmail support phone number and ask the help to solve all Juno-related issues within a short span of time.
Juno Customer Support Phone Number
on Apr 11, 2017 | Miscellaneous
Can you tell me where to get a manual for a Canon MP20DH 2 color display calculator?
http://www.manualsonline.com/ex/product/headline/m/canon/d/calculator/p/MP20DH+III
Jun 26, 2014 | Canon MP20DH Electronic Calculator Missing...
Where can I get a manual for a Canon MP20DH calculator?
Jun 26, 2014 | Brother SX-4000 Typewriter
CANON ADDING MACHINE model MP20DH III DOES NOT PRINT CORRECTLY
May need to change the ink in it. Staples has them pretty cheap.
If you need further help, reach me via phone at https://www.6ya.com/expert/andrew_d2df42288260d96e
Apr 16, 2014 | Office Equipment & Supplies
Sc:542 error message on the screen
You need a firmware update…
SC542 SP1-103-2 Off + Temp has been newly added to prevent SC542 from occurring at machine power-on under low-temperature conditions.
Note: For this fix, it is necessary to use Controller firmware ver5.15.1 or newer.
Apr 02, 2010 | Ricoh Aficio 2015 Copier
Error Message
what is the error message ?
machne can lock on to mush soap
May 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Script error is coming instant message not going
I had this problem till yesterday. The culprit was some ad script in the messenger ads has stopped working because it was not compatible with my flashplayer. As a result I got the message that messenger has stopped working. Download and install the latest version of flashplayer to resolve this issue. This issue has been fixed in messenger 9.
Nov 25, 2008 | Yahoo Messenger
old marine
old marine
