Question about ASUS MyPal A626
ASUS MyPal A626 will not get past blue boot screen after soft or hard reset. power button does not work at all
4 Suggested Answers
SOURCE: ASUS MYPAL A636 will not turn on
Thank you very much, I had that problem and never thought that that hold switch was ever moved.
Posted on May 24, 2008
SOURCE: ASUS MyPal A626 Wouldn't boot
thank you this helped me repair my A626
Posted on Aug 21, 2008
  • 2973 Answers
SOURCE: ASus A626 - when push
It seems that for some reason the firmware has got corrupted. Please have it reinstalled from the Asus Service Center.
Posted on Oct 27, 2010
HOW TO REPLACE SCREEN ON ASUS A626
You have to visit Asus Service centre in you country
please visit www.asus.com and find the address of nearest service centre in your country.
Jan 23, 2010 | ASUS MyPal A626 Pocket PC
Asus A626 keeps cutting off
I had a problem similar to this, and I used YOUR solution to fix it. In fact looking for you to thank you for the idea is how I found this problem.
Sometimes even with the battery cover on and intact, the sensor does not correctly detect it. My screen was turning off randomly and sometimes would not even get through the Asus init before it would turn off again.
So, looking at the solution you posted I pushed a small wad of Kleenex in the hole and then put the cover back on. It's been running fine for almost a day now.
So, thanks for the suggestion. I had no idea that sensor was there.
Jan 04, 2010 | ASUS MyPal A626 Pocket PC
Asus A639 wont start
I had this problem on my A639 after going on holiday with it (I think the x-ray scanners did something to it). It started switching itself off more and more as the days went by until one day it went off and never came back. After resetting it, it just stayed on the blue "ASUS Rock Solid Heart Touching" screen. I was worried that it was totally broken and I'd have to pay to get it repaired, but after searching the internet it turned out all I needed to do was re-flash the ROM with a fresh copy (I used the latest ROM). It now works fine and no longer turns itself off... didn't cost me ANYTHING to fix :-)
Check out this webpage for more info:
http://forum.xda-developers.com/showthread.php?t=401850
Nov 23, 2009 | ASUS MyPal A639 Pocket PC
Asus mypal a626 will not stay connected to cisco
hello,
ok take a look for connection and securite setting in asus.
Sep 10, 2009 | ASUS MyPal A626 Pocket PC
I am trying to connect my asus mypal to my wireless internet
Hi, I helped a friend of mine with his wifi setup. His WEP Key was on the side of his router. I don't remember the exact work but it was something Key. It was 10 numbers long just right for a 64 bit key. If you are using Win XP there is a wifi setup in there. I have a mypal A626 and had it up and running in a few minutes on my wifi system. If you have security, you will need to find the code in order to get a connection. grader01
Apr 12, 2009 | ASUS MyPal A626
Cannot remove the calendar events
Did your friend do a "hard reset" of the PDA before she gave it to you? A hard reset should erase all user settings and data, returning the system to its default state.
The ASUS 626 User Manual (Ch. 1, Pg. 4) refers to this process as a "clean reset". The following instructions were extracted from the user guide:
NOTE To perform a clean reset, press the launch button and
simultaneously pressing the stylus on the reset switch. Then
a warning message appears. Press to do clean reset, or
press to leave the operation screen.
Performing a soft reset will not change the data in the device;
while performing a clean reset will delete all data
Mar 05, 2009 | ASUS MyPal A626 Pocket PC
On the right side of your ASUS A626 there is a switch that says "HOLD". Make sure that isn't flipped on.
-Sean
Apr 02, 2008 | ASUS MyPal A626
Asus PDA
PRESS THE center button and the reset button at same time..
and then choose
Restore
after u finished the above steps ....try use computer connect ur pda again.
Mar 11, 2008 | ASUS MyPal A626
4 GB Expansion (ASUS A626)
Yes, my card of 4gb works perfectly, thank you very much.
From El Salvador Central América.
phone:(503)7774-2842
Feb 06, 2008 | ASUS MyPal A626
If you haven't tried already flip the switch behind the device....
Dec 04, 2007 | ASUS MyPal A636
ASUS MyPal A626 Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
