Question about Isuzu Vehicle Parts & Accessories
Isuzu kb 250 CSD relay energises and prevents the fuel solenoid to open
What is causing the CSD relay to energise
  • 958 Answers
SOURCE: hot water solenoid not energising i.e. no hot fill.
check the water setting.
it could be set to cold and not warm or hot that is why it is not energizing the hot water solenoid.
tnx 4 using fixya.
drcool
check also temperature setting of water. if it is set to cold, then hot water will not be energized. or it could be the defective part.
tnx again,
drcool
Posted on Sep 26, 2008
erpaalai
  • 999 Answers
SOURCE: Mains water solenoid valve inoperable
Trace back from the valve to the main connection. Could be a broken wire, a bad door switch, or timer/control.
Eric
Posted on Jan 13, 2010
  • 382 Answers
SOURCE: ignition starter relay not energising
dear sir
please check all fuse is ok and not broken and open your car control panel and open starter relay after that check by an D.C. Tester and key turn to start position and check D.C. supply is coming on relay if supply is coming and relay won,t work then this relay is faulty and need to replace .
hope answer the question
thank you
please vote!
Posted on Oct 04, 2010
duane_wong
  • 6826 Answers
SOURCE: problem is that the AC
check for the cut off switch or sensor on the a/c plumbing to see if normally closed or normally open, and if it is causing the the AC Cut of relay to be energized permanently.
See if disconnecting the switch on the plumbinug changes anything. Or if using a test light to ground out the terminals does anything different on the AC system.
Posted on Feb 03, 2011
SOURCE: Starting problem, VZ commodore V6
Hey mate, I have the same problem. Try switching that relay with one of the other relays first to see if its that.
I have a suspicion that it might be ignition related as I though I smelt unburnt fuel in the exhaust. I could be wrong though.
Im going to have a look today, and will let you know how I get on.
How many k's has your car done?
Posted on Jun 13, 2011
1985 F-150 351 windsor Engine will not crank.Have new batt,Fender ignition solenoid,starter
You check the relay out for the starter also did you try to trip the solenoid on the firewall to see if it cranks from that just to eliminate because if it cranks from tripping the solenoid and what you stated you replaced is new and not used I would say in the ignition but if you replaced with used parts good chance could be a bad starter unless it was tested as well as solenoid it can be a dud
Jan 21, 2017 | Cars & Trucks
I have a 2008 Yamaha YDRE electric golf cart, I replaced the solenoid. I have checked the key switch, the f/r switch and the toggle switch. I only have a positive reading on one side of the solenoid.
Only the battery side of the solenoid will be live until it receives an energising supply from the control circuitry and closes. In the energised and closed condition both sides of the solenoid will be live.
If an energising supply is present at the solenoid coil the solenoid could be faulty. If the energising supply is absent the control circuitry is at fault. Tracing the fault could be made easier by referring to a wiring diagram.
Oct 14, 2016 | Golf
Spa Power 750 safety relays on control board (two top on right) have 230v in but are not closing. what are the likely causes?
Safety relay coils will be part of a circuit designed to prevent something from happening until the conditions are safe, a pump perhaps, that will not be allowed to start unless there is sufficient water or a heater that should not operate without sufficient water.
The relays will not close until the circuit the coil is part of is complete. There will be the supply, the coil, various connections and possibly wiring and then a sensor or a switch or possibly two or even more switches and then a return path to a neutral, ground or negative depending on the circuit design and voltages. Relay contacts often control higher voltages than the coil uses so there might be 230 volts at the relay contacts but only 12 volts needed to energise the coil and close the contacts.
While there are relays designed to be energised by ac mains voltages, designers mostly choose low voltage dc and so there could be problems with a power supply.
When fault-finding on such an installation it is wise to first discover how the circuit is supposed to operate, ideally with the aid of a circuit diagram. This is especially important when relay coils are energised by the means of electronics instead of direct connection with sensors or control switches, which is not unusual.
Jun 27, 2016 | Pool & Spa
How can i bleed isuzu kb 250
pull the fuel pump relay running
the fast foot the throttle pedal to prevent the pending stall
now pressure be lowest.
safe way
not getting fuel in eyes is a win
Jan 25, 2016 | Isuzu Cars & Trucks
Mercedes benz mb140d no power to glow plugs
check the relay that the ignition switch energises on starting . There should be a fuse to allow the relay to energise.
Oct 07, 2013 | Tailor-Made Sheepskin Covers, Pairs for a...
Problem is that the AC CUT OFF relay energised permanently. therefore electric clutch of compressor swicthed off permanatly, because current to compressor clutch goes through NC (Normally Closed) contact...
Feb 03, 2011 | Ford Econoline Cars & Trucks
99 explorer fan only works on high
You need a blower motor resistor pack, follow the wire from the motor it will go into a connector with a few wires at the resistor pack. it's held in by 2 screws- easy to change.
Jan 22, 2011 | 1999 Ford Explorer
Dryer will not heat up
Unlike electric dryers gas dryers will continue to run if the thermal fuse is blown. Usually some sort of air blockage will cause the thermal fuse to blow. The control thermostat powers up the gas assembly.cd79cfa.jpg It judges the drum temp as air passes over it on its way out the exhaust. It opens(quits sending electricity to the gas assembly) at 160f for cotton and closes(starts sending power to the gas assembly) again at 105f.
When the dryer is running and the timer is set for heat, the control thermostat is energised. It powers up the flame (ignitor) sensor, the ignitor, and the solenoids. The gas does not come out with those solenoids energised because the ignitor is using most of the power to get it lit. When the ignitor is glowing wide open the heat from it causes a bi-metal in the flame/ignitor sensor to bend and open the circuit to that ignitor. That kills power only to the ignitor. The resulting power surge causes the solenoids to yank open them flood gates and raw gas comes out onto that screaming hot ignitor. KAWOOOSHHHH Houston we has ignition. At this point the ignitor becomes a safety device. As long as the flame is washing through that ignitor the current keeps flowing to them solenoids and the gas keeps a coming. If for some reason their was no ignition the ignitor would cool down and shut off the solenoids. More here
Jul 25, 2010 | Whirlpool WED5520SQ Gas Dryer
91 Roadmaster, Auto A/C, no power to A/C relay. What should I check first?
1- Check the fuses, switches etc (its the most obvious places, and cheapest to check)
2- Check your freon - if you have an a/c gas leak, the pressure switch on the gas line (a/c gas, not fuel!) cuts out, causing the relay to de-energise. It's a safety measure to prevent damage to the compressor if the pressure is too low.
I hope this helps!
Jun 14, 2009 | 1991 Buick Roadmaster
Hot water solenoid not energising i.e. no hot fill.
tnx 4 using fixya.
drcool
tnx again,
drcool
Sep 26, 2008 | Indesit W 123 Front Load Washer
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Isuzu Vehicle Parts & Accessories Experts
Randy Ohler
George Agios
George Agios
SriPhi
Are you an Isuzu Vehicle Part and Accessory Expert? Answer questions, earn points and help others
