Question about Hotpoint Repair Pcb / Module Wf240 Wf250 Wf310 Wf320
Hotpoint WF310 no power light
When turn on at mains lights blink on then nothing
5 Suggested Answers
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
  • 15 Answers
SOURCE: Hotpoint Aquarius WF310 Hi I
i have flashing lights problem not dangerous. bearings may b gone or going
Posted on Mar 23, 2011
caroldon
  • 17129 Answers
SOURCE: Wf310 wont start lights are
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
start with the door switch as if this is faulty the program controller will not work.If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Posted on Jul 02, 2011
  • 6277 Answers
SOURCE: im looking for a programm
Sorry, this FixYa Washer Forum does not supply service centre numbers, engineers, spares or spares sources, software, installation instructions or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in your local telephone directories OR stay on line and search for '(make) washer spares' and hope that you can find someone/somewhere reasonably local.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 19, 2011
Door lock light not coming on and cycle not starting on my Aquarius WF310
I fixed mine by ordering a $49.00 door switch # 34001265 from eBay. remove door seal ,3 screws and now I am washing again. saves $80.00 service $79.00 local parts.
Jul 26, 2014 | Hotpoint Washing Machines
The door lock light will not come on our hotpoint aquarius WF310 and the machine will not start
Un-plug the machine, remove the spring that hold the door seal look in at the door lock switch, usually it is broken . order the door lock switch for $50.00 MY eBay. p/n 34001265
TV won't turn on. Red standby light blinks
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
Nov 06, 2013 | Samsung BN94-05038F Main Board for...
Wf310 hotpoint aquarius washing machine wont spin or drain
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf310 set wash,it starts then after about 20 seconds the on/of light and the lights to the far left flash
you will have to check the error code number which you get as per the blinks.
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
ignore the on off light
as per the fault mentioned you will have to check the fault in your unit and then replace that following part in your unit.
you can get required parts from
www.repairclinic.com and also from www.partselect.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 27, 2009 | Dishwashers
All Lights Flashing on Hotoint Aquarious WF310 Washing Machine
Means that the heat sensor is broken.
Replace that and it should fix your problem
May 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint stove
the light only indicates that the oven elements are on.A blinking light i would have checked out for a short
Nov 22, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint Repair Pcb / Module Wf240 Wf250 Wf310 Wf320 Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
