Working normally this morning.
SOURCE: Kitchen and bathroom faucets do not get hot,hot.Lukewarm at best.
ok the way it works man is the box aka power vent the gas valve wont open until the power vent is open u can manualy open the powervent witch will open the gas valve to turn on the piolt light and in about 30 sec the main burner will kick on now if the powervent is opening the the pilot light isnt lighting then u need to replace the thurmole cuple witch sences the pilot light is on if it doesnt see the pilot the it shuts the gas valve off so it doesnt fill ur house with gas
SOURCE: i have the number 760 appear on the screen when
http://www.bosch.com.au/content/language1/downloads/bc2600_Owners_Guide.pdf
Above is a guide that may be of help to you. Below is a Bosch technical support site...
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/tabid/334/Default.aspx
Try unplugging the unit's power cord or shutting down the breaker or fuse at the power panel. This should "reboot" the computer chip on the control board and return the unit to normal operation. Losing power has an adverse effect on computer chips and memory sometimes, and a reboot will right the ship on most occasions
I have not seen this exact fault code? However the 7 series, usually indicates a problem with either the temperature, maybe a sensor, thermostat, or the Main Board? As with ALL gas appliances, I am bound to tell you to seek professional help.. so that's indeed what i advise, contact a professional and go from there?
SOURCE: have a Bosch TF250 get water to bathroom but not to kitchen how to fix
Replace your single handle faucet cartridge
http://waterheatertimer.org/Crossover.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
