Question about Stairmaster Exercise & Fitness
Stairmaster le 1650
Peddles on 1650le slipping
  • Stairmaster Master
  • 914 Answers
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: stairmaster pedal slip
Sound s like it maybe the hub assembly they have a one-way bearing in them and that could be cause the problem go to
http://www.gympart.com/ or call them 1-800-496-7278 they will have the parts for your
Posted on Apr 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: stairmaster freeclimber 4400pt how to fix slipping
This could be the hub assembly slipping I would replace this assembly and the pedal chains call National Gym Supply @ 800-496-7278 and get pricing for the hub assembly and step chain ( L & R )
Posted on Jun 01, 2010
My Nautilus 4600cl right side slips.Would the drive hub be the probable cause?
Most commonly if one side slips and not the other, you are looking at the drive hub sprocket on the side that is slipping. Chances are, if you are experiencing slipping on one side and not the other, the one that is not slipping, is not far behind. It would be in your best interest to purchase the whole drive hub assembly.
Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Nov 23, 2012 | Stairmaster 4600CL Stepper Blue Console...
Stairmaster 4000pt pedal slips
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Jul 07, 2012 | Stairmaster 4600PT Stepper
The left peddle has a periodic quick drop as if it is slipping or something. There is a low popping sound whenever this happens. The drop is very slight and occurs about once a minute.
Mar 17, 2011 | Stairmaster 4400 PT Stair Stepper
Stairmaster 4400pt seems to have a slipping chain.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You can take the covers off and see if it is indeed the chain that is slipping, but in most cases, the drive sprocket is actually what is failing. The following link will take you the item that should rectify your issue.
Nov 04, 2010 | Stairmaster 4400 PT Stair Stepper
I have a stairmaster 4400cl and the right hand pedal intermittently slips and drops to the floor. it only does this a few times every 5 minutes or so. when i put weight back on the left pedal and start...
Oct 17, 2010 | Stairmaster 4400CL Stepper
Stairmaster 4400 display went dead and now there is no resistance to the peddles and the display doesn't pop up at the start of excercise.
Investigate the battery on this unit. The machine uses a 6volt battery. If there is no power, there cannot be any resistance.
Sep 24, 2010 | Stairmaster 4400CL Stepper
Stairmaster freeclimber 4400pt how to fix slipping chain. When using the machine the chain slips intermittently on both sides. Problem was infrequent in the beginning but getting worse all the time with...
May 25, 2010 | Stairmaster Exercise & Fitness
Stairmaster pedal slip
Jan 09, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Stairmaster 4600pt pedal falls without warning
i have the stairmaster 4000pt which was bought new in 2003. in 2007, i started experiencing the same problem, the right pedal would sometime slip and fall to the floor. i called the local fitness store and they came and replaced the hub assembly and that resolved the problem until now. The left pedal is now slipping.
Apr 14, 2009 | Stairmaster 4600PT Stepper
Exercise & Fitness Logo
90 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
