Question about Nikon Coolpix S9400
Blank green oled screen
Used 1 day now oled screen blank just a green screen. Charged battery.
Why does my Samsung i85 digital Camera does turn not on even with a new charged battery
Sure the battery is charged? Can you operate the camera with just the adapter? If so, does the camera work then. If so the new battery is defective.
Sep 24, 2017 | Samsung i85 Digital Camera
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
My archos 5 IMT 160 gb has a blank screen. It looks like is charged. I makes noise while is starting up, but the screen is blank. I* charged for over 10 hours.
Screen is blank?
Do you mean you won't see anything at all like the signup colorful screen that says "ARCHOS Entertaining your way" ?
If your battery is full charged (did  the CHG LED green light blink when it finished charging?), and you have a blank screen, do you have a serious problem indeed. If your unit is under warranty your best and only way is contact Archos.
If when you turn it on, it takes you to the Recovery screen (white screen, usually says Code 101) then try to Format the HDD, download the latest firmware from www.archos.com for your unit, copy it from your PC to the Archos, let it finish the process wth the power supply connected, and once it's done the unit should be back working fine with the latest fimware.
But if you definetely do not see anything but a blank screen when you turn it off, your problem is more serious than a simple firmware upgrade, and you need to contact Archos tech support.
Mar 08, 2010 | Archos Internet Media Tablet MP3 Player
NAVIGON 7100 WON'T TURN ON
your battery is gone requires new one.
Aug 20, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Blank screen
try without the battery connected
Mar 22, 2009 | Acer Aspire One PC Notebook
Blank screen
Try removing the battery and putting it back in again. If it still doesn't come on it could be that the battery needs replacing.
Dec 22, 2008 | Uniden Cordless Phone
Both upper and lower screens are blank
You may be mistaking it saying it is charging with saying it is low battery. Green = Battery is well charged, Red = getting low, Flashing Red = Very low, Orange = Charging.
If you are certain that it is saying it is charged, charge it anyway, it probably is uncharged but is confused about whether it is charged or not. Remember that this is a machine: it has no brain, and cannot think for itself. All machines are stupid, they can only think what you tell them to think, and you have to be careful or it trips over itself and breaks.
Jan 02, 2008 | Nintendo DS Lite Console
Blank Screen
If it is under warranty return it asap or report the problem...
http://www.tomtom.com/support/index.php?Lid=1
Dec 03, 2007 | Tomtom GO 300 GPS Receiver
Nikon Coolpix S9400 Logo
23 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
