Question about Epson LQ-2090 Matrix Printer
How to define a custom paper
I have to set a custom paper with an EPSON LQ-2090 Matrix Printer, but I'm not sure if I need a special driver. Please help me. Thanks.
Sir,
I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for WindowsXp using printer Epson-LQ-2090. immediately
Posted on Aug 17, 2009
What setting to do , if i insert thick paper or plastic sheet to be printed
make and model of machine please? it depends on if you are printing or copying to the special media. there are settings on the control panel as well as in the print driver to select special media types. beware of "plastic sheets" and any coated paper if you are using a laser device that has a fusing unit that heats the media to fuse the toner. using the wrong media can cause major damage.
Feb 06, 2016 | Epson Dot Matrix LQ-2090 Printer
When I print a multiple page document on tear paper roll, the first page prints correctly but the pages after that start printing too near to paper tear size or up to paper tear size. What should I do
Sounds like your top margin is not either not set properly or your documents do not have page feed command at the end. Are you sure you have the correct driver installed?
Nov 23, 2014 | Epson Dot Matrix LQ-2090 Printer
My epson lq 2090 paper load problem occurred find the solution about that
It's very cold in your place? And the paper is tick? I noticed problem with tick paper in the cold season, but i'mnot very sure about this.
Dec 20, 2010 | Epson LQ-2090 Matrix Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
Printer Epson LQ 2090 ask to insert paper for every pages
Please take note of the paper used. Letter Size A4 or custom. This can be set on the PC (Mac or Window). If not you may just reset the hardware by holding the 1st and 3rd button and then power on. You may hear a beep sound after resetting. Good luck
Sep 02, 2009 | Epson LQ-2090 Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Add custom paper size in lq-300+
Control Panel - Printers - right click over blank space - server properties, you can fill whatever you want size.
Apr 23, 2009 | Epson LQ 300+ Matrix Printer
Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Jun 11, 2008 | Epson LQ-2090 Matrix Printer
Epson LQ-2090 Matrix Printer Logo
476 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
