Question about HP Officejet Pro L7590 All-in-One InkJet Printer
Will not clear paper Jam message, Makes horrible clicking sound
I have a HP L7590, I was printing a small piece of paper got jammed in the machine. I finally found it sitting in the right side of the printer where you lift up the access panel once you flip the lid. I hit o.k. it starts to go through the process of setting its self up. Right at the end there is this really loud clicking sound on the right hand side and the Jam message comes up again. I watched it with the lid up and looks like a sponge like piece is trying to do something but is not getting it done?
  • robertgbell May 19, 2009
    I had gone through this step to clear the paper Jam. There is no paper jammed in the machine. The problem now is this clicking sound under the right access cover when you lift up the whole print tray. Something is not engaging properly and is giving me an error message. Sound like plastic poping.
    I have already cleared any paper in the machine. It is the last part of the reset stage the slider goes all the way to the right and under the slider I there is this really bad clicking sound Plastic. I have watched it with the tray up and there is a sponge set into a small plastic frame looks like it is trying to move forward but isn't making it.
    Top Expert:
  • HP Master
  • 76,682 Answers
U have broken a part in the paper loading mechanism that much is certain, u will need to pull the printer apart and find out what is damaged, but most likely the cost to repair the printer will exceed the cost to replace it, the printer is cheap, they make there money on the ink cartridges.
Posted on May 19, 2009
    Brigadier General:
  • 3,917 Answers
After a detailed research we were able to pull up the required troubleshootings steps to be done as proposed by HP. Bellow is the link :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&tmp_track_link=ot_faqs/top_issues/en_us/c00839319/loc:3&lc=en&dlc=en&cc=us&lang=en&product=3643612
Thank You
Just cleared paper jam. Now won't print. Only makes clunk sound
Check carefully to make sure there is not a small piece of paper still stuck I the printer and blocking the carriage. Also make sure that the cartridges are seated properly.
May 28, 2016 | HP PhotoSmart Office Equipment & Supplies
How do I override a paper jam error message?
Dear
I am a bit of confused about paper jam but you are able to print but facing difficulties in scanning. I think the document jam is there. Pl. check the ADF (automatic document feeder) a small piece of paper or any foreign mater may obstruct or jammed at the sensor. clearing this may help you.
Thanks.
Feb 25, 2015 | Brother DCP 8085DN
I am positive there is no paper jam with my printer (Z2420) but message of paper jam still appears and it won't let me clear it.
Sometimes a very small piece of paper can still be in the printer paper path after clearing a jam especially if the paper tears while removing the jam. The piece of paper may be too small to notice. Try blowing out the paper area with compressed air. Other causes could be the thickness of paper you are trying to print on, ie photo paper, thicker bond paper. Make sure the print settings match the paper thickness. I have a Lexmark laser printer, and I will get feed problems if the settings are not set for the correct paper type.
I hope this helps.
Alex
Feb 10, 2015 | Lexmark Z2420 USB 2.0/ 802.11g Wireless...
Paper jam, removed paper but still says jammed. Is there any way to tell where the jam is or reset machine ?
You should be able to have a piece of paper feed all the way without hanging.
Most of the times, you can see a small piece of paper stuck in a corner.
I have used a cut piece of plastic ( from a file folder ) and worked small pieces out that way.
Good luck, Happy Holiday's
Nov 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I get paper jam message
A paper must have stucked in the printer. Kindly open the printer where you enter the toner. Take the toner out and then look for any piece of paper or something has stucked. After clearing it, Place the toner back and then try to print....
Aug 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
New out of the box 13:20 error paper jam there has never been any paper in machine we're just setting up. open and close front, then theres a fuser jam lift and close top, front door again.We have paper in...
PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Jun 24, 2009 | HP LaserJet 3600n Printer
Error Message - Paper Jam
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Feb 25, 2009 | HP Officejet Pro L7680 All-In-One Printer
Cleared paper jam &printer will not reset
I had to turn off the printer & disconnect the power cord. I also had some material that was backed up on hold from the night before that was preventing the current material from being printed & I had to go in & cancel the documents to be printed before the printer would function.
Jan 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
