Wont retain supply water
Lg fussy logic wont retain supply water
    President:
  • 1,136 Answers
Hi, First thing to look for is that you drain hose is higher then the water level in the washer. If your darin hose is laying down near the sump pump, make sure the end is not laying in the water in the sump. I hope this helps you. Please let me know if I can help further.
Thanks
Vic
Posted on May 19, 2009
We have a LG Fuzzy logic 5.0kg WF-T507. When not working, cold water is slowly leaking into the tub. The hot water is also not flowing when needed.
The fill valve could be defective but the leakage into the machine when idle could be caused by supply line(s) above the fill valve level. Some manufacturers recommend turning off the supply between wash sessions but in practice that tends to be impractical.
Feb 12, 2017 | LG Washing Machines
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
May 19, 2015 | LG Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
I have a LG fuzzy logic the problem is that its not stopping the water input its over flowing ....
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If the water frequency level fails to reach 246 in 8 minutes you will get an IE error or inlet error. You would need to check the water valve, water pressure, etc.
How does the machine know if the water level is complete? Water level switch right? So obviously the control is timing the amount of time it takes till the water level switch kicks off. If it takes more than 8 minutes we have a problem don't we? Therefore if something is partially blocking the tubing from tub to switch that might throw off the water level switch. It is located on the main control assembly and has the rubber tube connected to it. The control board uses this to determine water frequency level. Just blowing the sediment out of that tubing will cure the IE error IF everything else mentioned is all good. I meself would do that first before replacing any parts.
LG WASHER MANUAL
Aug 04, 2012 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
I have an LG fuzzy logic and it keeps flashig 1E and just wont do a wash help
1E = WATER INLET ERROR
• Correct water level (2 level) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Check water line strainers for any blockage Check that the water supply lines are opened all the way. Replace water inlet valve if above conditions are met.
Happy Holidays The FixYa Team
Dec 24, 2010 | LG Washing Machines
STARTED, ROTATED A FEW TIMES, FILLED UP WITH WATER, NEXT MODE "WASH" BEEP BEEP. BEEP BEEP.. "d E" .. MACHINE STOP. POWER STILL ON. CONTROL BUTTONS STILL FUNCTIONING. IT IS A LG...
he error code "dE" signifies a door open error. This may simply be because the door is not all the way closed, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
Dec 11, 2010 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
