Question about Grohe Rainshower Shower Head - 28373/Choose Finish=Satin Nickel
Shower will not get hot enough
I have wireless grohe shower model 36023 high pressure mains unit running from a mega flow that will not get very hot. I have scalding water going to the unit and I have checked the filters. The water is only luke warm when i set the shower to a max temp of 60 deg A few days ago I restricted the cold supply and thought this had solved the problem as all was well probably the best it has ever been but it has slipped back to how it was.can any body help please
Regards John
  • Anonymous Mar 14, 2014
    water leak
  • 56 Answers
I have no experience in fixing showers however mine once did this when i remodeled my bathroom so i called one of the guys that was workin on it and he told me that he had takin something out what looked like a gasket and said it was a scald preventer and from then on my shower has been fine hope this helped
Posted on May 19, 2009
I need to put back flow restrictor in Grohe shower head due to drought, how do I do ?
are you sure that is where it needs to be . as I have never heard of them being attached to a shower head . usually they will be put on the main water inlet line to the home or business
Jun 21, 2015 | Grohe Home
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
Only cold water coming from Grohtherm wireless 36023
There are multiple possibilities:
- the power to the main control could be off (seems unlikely if you can turn the water flow on and off)
- the thermal element that heats the water could be burned out (may not be a problem if this is only a mixer unit and relies on external hot water supply)
- there could be a problem with the solenoid that opens to allow hot water to flow through the unit
- there could be either no hot water getting to the unit or blockage so that hot water will not flow through to the mixer
Start by making sure there is power. Then you may need to disconnect the hot water supply (after turning it off at the source) and then check to see that hot water will flow. If you get hot water to the unit then there is something internal keeping the hot water from mixing with the cold.
Oct 28, 2014 | Grohe Home
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Grohe wireless HP electric shower has service code 01 on main switch in shower, and no flow of water.
I had the same Service Code 01. The solution is simple. Switch off the power for the shower for a minute or so usually located outside of the bathroom. Switch it back on and you should hear the unit (if it's close by) resetting itself. Switch on the shower and it will tell you to wait, then with a bit of luck it should wizz into action.
Sep 14, 2010 | Home
We installed a Grohe Relaxa Plus 10 years ago.
Likely a blockage in the line. Corrosion or other damaged parts. Try cleaning the filter screen first. Check for normal water flow without the shower unit attached to the spout. If OK, then the unit is the issue.
Aug 24, 2017 | Grohe 24'' Relexa Shower Bar with Swivel...
Low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Dec 20, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Grohe Rainshower Shower Head - 28373/Choose Finish=Satin Nickel Logo
862 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
