Question about HP Pavilion F1703 17" LCD Monitor
OSD main menu pop-up will not go away
I have an HP pavilionf1703 monitor. There are 2 blue squares on top of each other. the one in the background shoes OSD main menu. The one on top is the brightness/contrast display. I can't seem to get them to go away even by pressing the buttons on the monitor itself. The cursor is underneath these squares so I can't click on anything.It has been driving me crazy. I unplugged the monitor, plugged back in and it goes away for a little while.Any help would be greatly appreciated. My knowledge of computers is not that great. Linda
  • llamplighter May 30, 2009
    thanks eeugenio24 for the advice, but it didn't help. I am really at my wits end and am ready to trash the monitor!!!!
    llamplighter@verizon.net
    Sergeant:
    Champion:
  • 225 Answers
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
Posted on May 23, 2009
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
I have an HP pavilionf1703 monitor. Two blue squares on
If the cursor is hidden use the keyboard: Press the TAB key and cycle the options. When you reach the one you want press ENTER
Hope it helps.
Aug 30, 2009 | HP Pavilion F1703 17" LCD Monitor
The osd main menu has appeared on my hp pavilion f1703 monitor
Control Panel->System->Hardware->Device Manager->Monitor. select and uninstall. Then let Windows detect the monitor and re-install the drivers for your monitor. Do the same for the disply adapter in the Ctrl Panel.
Aug 24, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
CANNOT REMOVE THE OSD MAIN MENU FROM MONITOR SCREEN
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Jul 23, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
Menu option
stuck in adjusting button?
Oct 11, 2007 | HP f1905 19" Flat Panel LCD Monitor
HP 1530 Onscreen Menu refuses to go away
the button is bad on it the select OSD button
the cable is bad, and tells you out range, no signal, or other cable dead errors or in sleep mode. can be PC, cable or monitor
id have to see your screen to wax smarter.
unplug monitor from power and pc
let sit for 1hr.
the plug it in all alone
does OSD pop up> is there an error
if no error there, the monitor buttons are broken,
Jun 10, 2017 | HP L1530 (Carbonite, Silver) 15" LCD...
HP Pavilion F1703 17" LCD Monitor Logo
621 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
