Question about Palm Treo 750v Smartphone
Bluetooth problems i have a sony bluetooth car audio and a palm treo 750v i have connected them together and when i make a call its fine but when the phone rings the sony car audio does not pick up the call
Beni S-P
  • 1006 Answers
SOURCE: Software upgrade makes bluetooth unworkable
I think this can help you:
Treo 650 only
A zero out reset will regress a device that has non-volatile memory to its factory-fresh state. When done correctly, it completely rewrites your device's internal memory with zeros and ones, ensuring that any data is expunged. It should be used only if you want all information completely obliterated (example: you're selling your handheld, or you're sending it in for repair, and want to protect your privacy). Tungsten E2 note: a hard reset (above) produces the same results as a zero out reset - completely rewrites data on internal memory. No need to perform the steps below. Warning: A zero out reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a zero out reset unless you want to eradicate everyting.
spacer.gif HotSync note: Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
There are two ways to perform a zero out reset.
  1. Read through these instructions before attempting the reset. We made this method of zero out reset extremely awkward to perform, so that it would not happen by accident. You may need the help of a dextrous friend if you find it too difficult to do by yourself.
  2. Connect your device to its HotSync cable or cradle. The HotSync cable does not need to be connected to your PC, and it does not need to be connected to power.
  3. Press and hold the Power button and UP on the 5-way navigator.
  4. While continuing to hold Power and UP, press and hold the HotSync button on the HotSync cable or cradle. As you press HotSync, make sure your other finger doesn't slide to LEFT or RIGHT on the 5-way navigator; it needs to be exactly on UP during the entire process. Although you are pressing the HotSync button, a HotSync operation should not begin.
  5. While continuing to hold Power, UP and HotSync, press and release the RESET button on the back panel of your device (where's the reset hole?). This is very difficult to do with only one person; you may wish to hold the stylus in your mouth and use your hands to press Power, UP and HotSync.
  6. Release Power, UP and HotSync.
  7. If you did this reset correctly, the screen of your device will go blank, and you will not be able to turn it on. The charging LED will not light up, even if it's connected to power. It will appear to be "dead." (any other activity — such as the Palm OS logo or a rainbow-colored Boot Log screen appearing — means the reset was performed incorrectly; try again)
  8. Your device will appear "dead" for several minutes (up to 10 minutes). During this time, your device's internal memory is being reformatted. If your device doesn't appear "dead" for several minutes with the screen completely blank, the zero out reset was performed incorrectly; try again.
  9. After several minutes, your device will "wake up" and the Palm and Palm Powered logos will appear as if you had performed a hard reset. Eventually, you'll be taken to a series of screens to calibrate the touchscreen and set date & time.
  10. If you want your handheld to remain in factory state, stop here. If you want to restore data to your device, follow the steps for recovering after a hard reset (a zero out reset is a special type of hard reset).
Quick Erase, Secure Erase
LifeDrive only When you perform a hard reset on a LifeDrive mobile manager, you will see two options on the reset screen: Quick Erase and Secure Erase. Both of these are types of hard reset. Quick Erase: Perform a Quick Erase reset for a regular hard reset, to get your device to wake up and respond again. This eliminates user information on the drive in such a way that there is no info available to anyone using the device. A Quick Erase reset takes approximately 5 minutes.
spacer.gif spacer.gif spacer.gif Secure Erase: Perform a Secure Erase reset if you are turning the device over to a new owner. A Secure Erase helps prevent your files from being restored or recompiled by a new owner who might remove the hard drive and use a drive reader to access your information. This completely deletes all user info on the drive. A Secure Erase reset takes about 30 minutes.
Note: If you use a password to protect your device, you must do a Secure Erase when you hard reset your device; the Quick Erase option does not appear on the reset screen.
  1. Slide the power switch to the right and hold it in that position.
  2. While holding the switch to the right, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button on the bottom of your device.
  3. Wait for the reset screen to appear (it will say "Warning, Erase all data?"). Then release the power switch.
  4. Choose your type of reset:
    • Press Up on the 5-way navigator to perform a Quick Erase (5 minutes)
    • Press Down to perform a Secure Erase (30 minutes).
  5. During the reset process, a status screen appears with the words "Quick Erase" or "Secure Erase" and a progress bar, followed by screens showing the Palm, Palm Powered and LifeDrive logos.
  6. Then you will be prompted to tap the screen to align the digitizer and select the language you want to use on your device. A screen appears showing the Palm logo and a progress bar.
  7. When the "Welcome: Setup your device" screen appears, the hard reset is complete. Follow the onscreen instructions to set up your device.
Posted on Nov 10, 2007
SOURCE: Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Posted on Dec 12, 2007
SOURCE: Palm treo 650
The 650 seems to have a delicate headphone/mic jack. Dropping the phone, even gently, seems mess up that jack. I returned my first treo 650 as defective, and got a new one. The same thing happened to my new 650 after I simply compressed the phone in my breast coat pocket by holding my mail against my chest.
I can't get a new one because the replacement treo comes with no warranty of any kind. :(
My advice would be to find a PDA/phone repair service to repair the jack or diagnose the problem if it turns out not to be the jack.
Posted on Jan 17, 2008
SOURCE: Palm Treo 750v
Have you tried removing the battery then putting it back in?
Posted on May 25, 2008
SOURCE: pairing a AtivaBT220 to a palm treo 755
how can i put a protective password on my treo so no one else can access my phone unless they put a keycode?
Posted on Sep 23, 2008
  • 928 Answers
SOURCE: palm treo 750v, problems with usb port, cd-installing.....
Already replied to your email
Posted on Nov 07, 2008
0 characters
1 Points
Can't hear anything - if I call a number I don't even hear the ringing tone and when the othe party answers - nothing...... oh dear!!
i had this problem with my tmobile shadow. i had to get a bluetooth earpiece and everything worked fine. if not you may need to get a new phone.
Jan 07, 2010 | Palm Treo 750v Smartphone
Unable to Synchronize with Vista 64 bit
Treo 650 can't be synced to Vista 64 via the cable, but Bluetooth works OK. Details later (I hope).
Apr 28, 2009 | Palm Treo 650 Handheld
How to upload songs in the palm treo 750?
if you got external memory card then put the songs in memory card through pc (if you laptop does not have the sd card slot then you need to do it with card reader)
or simply connect treo with pc through usb and upload it
Mar 24, 2009 | Palm Treo 750v Smartphone
I have a Mac laptop, a Palm Treo Wx and am now using a Motorola H700. I need to know how to sync my H700 with my Treo so I can dial via my headset and not need to use the actual cell phone. It has now...
Hi, i'm not sure what the Mac has to do with your Headset. You can register your blue tooth headset with any device that supports bluetooth. In fact, you can use your headset with multiple devices. Even your Mac can use bluetooth to connect to a headset (if you have bluetooth turned on, and not all Macs have factory bluetooth).
To 'register' your headset with the Treo is a two step process.
on the Treo, make sure bluetooth connectivity is turned on, then you should have a menu that allows you to find/enroll a new bluetooth device. Before you tell it to find a bluetooth device, turn on your headset. Now tell the Treo to search for devices. If it doesn't find your headset, then press and hold the button on the side and it will send out signals that your Treo will see. The Treo might give you a password code and ask you to confirm this is the device you want to synch to. Usually '0000', but in any case say yes, so long nobody else is around trying to do the same thing you are within 30'.
That should do it.
I don't think the Treo has voice recognition, which makes dialing on my Nokia a breeze, for true hands-free operation, nothing beats it.
Also note, the Treo has been know to have issues loosing bluetooth connectivity with the headset and not reconnecting with a re-boot.
so long you keep the two devices near each other, this shouldn't be a problem.
Jul 05, 2008 | Palm Treo 700w Smartphone
Palm Treo 750v
May 25, 2008 | Palm Treo 750v Smartphone
Bluetooth Problem
I had that problem once. I had to hard reset it and that fixed it.
Dec 01, 2007 | Palm Treo 650 Handheld
Bluetooth not working w
1. Treo 600 does not support Bluetooth! 2. The battery for the treo 600 is not removable unlike that of the treo 650.
Jul 02, 2007 | Palm Treo 600 Handheld
Palm Treo 750v Smartphone Logo
14 people viewed this question
Top Palm PDAs Experts
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
