Indesit bia 12f. Freezer works but ridge has stopped working. Any ideas
Freezer is working fine , fridge has stopped getting cold, light comes on but does not get cold. Turned thermostat in fridge up to max but still no cold air in fridge.
HVACRH20
  • 237 Answers
SOURCE: refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Posted on Jan 02, 2007
fridgetech
  • 473 Answers
SOURCE: Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Posted on Oct 10, 2007
fridgetech
  • 473 Answers
SOURCE: Freezer works; fridge side doesn't
First thing to check is look and see if there is  thick frost build up on the back lower panel inside the freezer?  If not there must be a problem in the damper (vent).  Let me know what you find so I can help.
Posted on Oct 21, 2007
the dr
  • 447 Answers
SOURCE: fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Posted on Jan 16, 2008
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
Ondesit fridge fridge freezer biaa134fh fridge not cold
It seems lots of people have the same problem with this appliance....including myself......I took the drawers out of the freezer.....removed the iced up plastic cover which houses the fan assembly.....some water had settled in the bottom and froze, therefore stopping it from turning.....just spin it and it with start up again.....hope it helps ;)
Mar 13, 2014 | Indesit BIAA134F White 9.5 Cu Ft Fridge...
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
LG FRIDGE,, fan not working or is thermostat faulty?
fan bad or not defrosting look for ice build up behind panel by fan
Oct 26, 2009 | LG Refrigerators
My frigidaire frc150ff fridge will not get cold
Completely defrost the fridge freezer, over 24 hours and switch back on, most times it will work properly again as this may need to be done on a yearly basis.
Sep 15, 2009 | Frigidaire Refrigerators
Fridge is running but won't get cold
if it have one compressor the gas in the system are low . but if it have 2 compressors the thermostat can be the problem
Jun 01, 2009 | Refrigerators
The fridge compartment not getting any cold air.
Well for whatever reason the fridge compartment is now getting cold air again and its all working fine. Have no idea whats gone on with it but is working again hahaha. The only thing that we did was take the back off the freezer, where it houses the fan motor, the motor wasnt quite straight so I straightened it and now its working. Whether that was the problem to begin with I have no idea.
Apr 12, 2009 | Westinghouse Refrigerators
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
