Question about Britannia SIE9TLS Electric Kitchen Range
Ovens do not reach temperature - Britannia SIE9TLS Electric Kitchen Range
The oven is set on 180 but only reaches 40. What can the problem be?
Check the thermostat inside the oven. If it has fallen from its bracket and is hanging down near the element, the temperature sensed will be too high and the oven will not reach the set temperature.
Nov 12, 2015 | Ovens
Why hasn't the oven reached the set temp when the buzzer sounds indicating desired temp has been reached?
What are you using to measure the temperature of the oven? If you using a typical round oven thermometer, the reason is that your thermometer response is slow. It takes about 20 minutes for those thermometers to reach and display the actual temperature, and your oven is probably reaching it's set temperature in about 10 minutes. You really need an electronic thermometer or at least one of those liquid thermometers which you can sometimes find at Ace Hardware or True Value Hardware stores.
Apr 29, 2015 | Kenmore Kitchen Ranges
How i know if oven reach the temperature i set for baking?
best way is to purchase a hanging oven thermometer it hangs on rack edge and you can view it thru door glass , some of the new ovens beep as well when they reach there setpoint for temperature
Mar 07, 2015 | Ovens
Why is the oven bell not ringing when it reaches the set temperature.
If the temperature reached at it operating temperature and oven display doesn't showing how much time left for ready screen then most probably its IO board gone.
I have seen many cases like this, and replacing IO Board fixed the problem.
Please rate my work
Thanks
Sagar
Sep 19, 2014 | TurboChef TORNADO Electric Oven
Temperature in Kenmore double oven will not reach
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 10, 2010 | Kenmore 47722 / 47724 / 47729 Electric...
The oven will not reach desired temperature. Had
it sounds like you have a bad temperature controller thermostat or your temperature sensor inside the oven, (a metal rod attached to a thin metal wire) is not in its proper place. It clips into connectors located at the back center of the oven itself.
Mar 14, 2010 | KitchenAid Superba KSRG25FK Side by Side...
GE XL44 Oven Temperature Issue
Have you tried replacing the bake ignitor yet?
Dec 06, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Britannia SIE9TLS Electric Kitchen Range Logo
14 people viewed this question
Top Britannia Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
