Question about Blue Mio Moov 330 GPS for Europe 4.3" screen Touch , tooth Car GPS Receiver
Usb driver mio 330 - Blue Mio Moov 330 GPS for Europe 4.3" screen Touch , tooth Car GPS Receiver
Pc not recognize usb device
Turn off computer...restart with Mio plugged in and on. It should find and load USB.
Mar 19, 2014 | Mio GPS
My mio 320 is stuck on transfer mode when connected to charger it thinks its connected to computer
I've had a lot of issues w/ the operation of my MIO C320, including this problem ... but ONLY whenever I tried using any other mini-USB cords (like from my phone or Garmin GPS chargers), with my MIO C320. There's something unique about the mini-USB pin-out configuration MIO uses that allows you to either charge or update their units (using the transfer function), using MIO's supplied mini-USB cables. (I've labeled my MIO cord as "MIO GPS", on a piece of masking tape wrapped around the cord.) I'm trying to recall whether the MIO's cords worked properly w/ all of my other devices, and I can't think of any that did NOT function properly. So, maybe you could experiment and - if that's the case w/ your devices also - avoid further issues by keeping JUST the MIO's charger in your vehicle?. Sorry this is so late, but I hope it helps! Cheers, The Foxxx
Jan 08, 2014 | Mio GPS
I turn on my device and it only loads up the start page and then hangs there .......
First try a reset... then try turning off the little power switch next to the reset, then turn it back on. If none of this works, your firmware is likely corrupted... then: You either need to return it to Mitac or locate (Google) & flash the firmware file into the unit as follows:
Connect the mio p550 to PC
1.put the Button of the PDA in ON position
2. hold the joystick downward and press the reset button
3.choose "Image Upgrade tools"
4.choose "0=Image by USB"
5.intall the usb driver (PC require the drivers). The driver in the
folder "USB driver" that comes with the firmware file.
6.open the software "dnw5.0e" (also comes with the firmware package).
7.(if you want to make a test of connection USB, click the "USB
port/Status". If all is ok go to step 8
8. click "USB port/transmitted" and to show the way of the file
"MioP550 - Osc260A R05_P09.nb0"
9.press the reset button to restart the mio p550.
Jul 09, 2010 | Mitac Mio P550 GPS Receiver
I formatted my p550 and I don't know how to bootup or reinstall the O/S
You'll need to find the firmware (ROM) image file (Google) and then: Connect the mio p550 to PC
folder "USB driver"
7.(if you want to make a test of connection USB, click the" USB
port/Statute". If all is ok go to step 8
Feb 22, 2010 | Mitac Mio P550 GPS Receiver
How can i update my mio digi walker c520??
The Users Manual and Support for MIO DigiWalker C520 is here.
I noticed this thread had been read 66000 times there:
onepixel.gif onepixel.gif Question: Is there a map update available for my C-series device?
Answer: We are working on newer map updates with Mio More Express software for C-series devices: C220/S, C320, C520, C720t. The products are in DVD media because the big size is not practical for download. Pleasse check back with Mio support later while slight USB driver issue is under investigation.
Oct 07, 2009 | Digi Mio Walker C520 Car GPS Receiver
My device is stuck on the usb connection display.
the question is yes of course it can be fixed, the cost of that repair may and most likely will exceed the cost of the GPS. So in most cases the best thing to do is just replace it.
Oct 01, 2009 | Blue Mio Moov 330 GPS for Europe 4.3"...
Mio c320 not detected by microsoft xp
The only thing it can be done is to rewrite the flash through j-tag method, but this must be done in service
Mar 09, 2009 | Mitac Mio C320 Car GPS Receiver
Lost installation CD
Doesn't that use Activesync? http://www.microsoft.com/windowsmobile/activesync/default.mspx USB driver is at http://www.mio-tech.be/en/support/168-downloads.php Hope that helps. Good luck
Aug 27, 2007 | Mitac Mio 168 Pocket PC
Blue Mio Moov 330 GPS for Europe 4.3" screen Touch , tooth Car GPS Receiver Logo
52 people viewed this question
Top Blue GPS Experts
Are you a Blue GPS Expert? Answer questions, earn points and help others
