Question about Compaq MV 520 Monitor
Monitor power up
When I turn the computer on, the green light on the monitor comes on for 5sec. then goes off. the orange light stays on.it all was working before but I unplugged it to move it in a different place, now just the monitor will not come on.
silly girl
  • 513 Answers
SOURCE: compaq tft 5005
Did the same and burnt a frazzled chip. it is on the 3rd circuit board (I believe it provides the lamp power). It is the 8 pin surface mount chip next to C900. As far as I can make out, the numbers on the chip are 4559 **** **7B I was told it's the lamp drive. If it is indeed lamp drive, then when you turn the monitor on, round the edges of a flashlight pressed to the screen, you should see a picture. If there isn't one, you may have killed more than I did. Is there no power regulator at the input? Good luck
Posted on May 23, 2006
  • 6 Answers
SOURCE: Compaq FS740
try pressing escape. or press f8 when your computer starts up and then press factory restore
Posted on Aug 27, 2008
frcs68
  • 1605 Answers
SOURCE: Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Posted on Oct 22, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: problem with compaq MV 520 monitor
Your monitor is operating normally. After Windows starts it is setting the video resolution to something outside of the monitor's range. That's why you see the Windows splash screen, then the message from the monitor about the settings. Most likely the computer was used before with a monitor that had a wider range of resolutions available.
Restart the computer. When the manufacturer's logo screen appears, press the F8 key three or four times. This should get you a startup menu screen. Pick the option of starting in VGA mode, and Windows will start with video settings that your monitor supports.
Posted on Feb 05, 2009
  • 583 Answers
SOURCE: compaq mv540 monitor does not come on when i turn
in a technical language you can say its a display problem. the monitor is fine.its actually the problem inside the pc.either some connections are loose or the ram memory needs to be cleaned or some part is gone faulty which needs to be checked.if any of this happens the display wont come.check all the above possibilities to reach the cause and solve the problem. please do rate the solution,thanks.
Posted on Jun 12, 2009
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
Monitor will not stay on
Generally Monitors have a single light in fron pannel, with dual mode colors as Green and Orange.
Green: Everything is OK .
Orange: Everything is OK, except it is not getting
any signals from computer or other source.
Try with any other monitor with your CPU, it may happen that CPU actually not providing any signal to Monitor. Try checking the "NUM LOCK" button on and off, whether it makes the light on keyboard to flash on or off.
If NUM LOCK is woking OK, there is surely some problme with your monitor and you need to get is checked physically with an engineer.
Jan 21, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor stopped working...checked all connections...light won't stay on green. bought a new monitor to replace it and that monitor says "no signal". is this a problem with the dell computer and not the...
Your monitor is going into power saving mode. When it receives no video signal from the computer, it will stay powered for a few seconds before giving up and presuming the PC is off hence why it stays green for a while, then goes orange.
The problem is with your PC not the monitor(s)
Jul 07, 2009 | Dell Computers & Internet
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Dell Monitor won't stay on
When it goes black, does the power buton stay green or is it orange? If it's orange, the power supply/inverter is your main culprit. If the power button stays green, it sounds like the backlight for the display is bad. Either way, unless you have parts for the same monitor laying around to swap out, you're due for a new monitor. The good news- with the economy in the tank, you can search online and find some reputable vendors selling nicely sized screens for less than $100! Heck, I've even seen a 22" for $129 (once but it was there).
Sep 23, 2008 | Dell E177FP LCD Monitor
Compaq MV 520 Monitor Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
