Question about RCA R52WM24 52" HDTV Projection Television
RCA HDTV TURNS ON THEM TURNS OFF WHEN IMAGE IS ABOUT TO POP OUT.
RCA HDTV turn off while I was showering try turning it back on.. it sound and the light turns on but then once the image is about to pop out it turns off.. then it turns on by it self at least 3 times and no image comes on.
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
SOURCE: power light flashes 3 times
U CAN THRO THE ******* THING BACK AT THE ******* PEOPLE WHO MADE IT!!!!!!!!!1 I GOT THE SAME ******* PROUBLEM AS THE OTHER GUYZ!!!! BUYING A **** N SONY NEVER AGIAN A RCA ********!!!
Posted on May 23, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Posted on Jun 29, 2008
800pctechs
  • 39 Answers
SOURCE: my rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Posted on Oct 02, 2008
fillmore85
  • 62 Answers
SOURCE: RCA HDTV Monitor D52W20 turns on and off by itself
I believe the high pictched noise you're refering to is the high voltage when your tv attempts to power on. When you say your tv turns on, is there anything on the screen? What I have experienced with several RCA itc222 is blown capacitors. When I attempted to turn the tv on it would try 3 times and then make me wait 45 seconds to try again. I don't know what to tell you about the blue light as I have never experienced that. But here is my solution if you'd like to try and fix it yourself. Be careful, but it is very doable.
I almost garantee that you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Posted on Jun 22, 2009
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Mar 04, 2011 | RCA HD52W59 HDTV Projection Television
RCA HD50LPW42. Sound so loud it sounds like a jet engine coming from TV (very loud whining sound). I assume this is my color-wheel, but I'm not sure.Turns off when TV turns off.
You need a replacement color wheel or have yours rebuilt since the RCA color wheels are on nationwide back order. You can get your wheel rebuilt at the following link
http://servicemanuals.vstore.ca/
Sep 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
My rca hdtv smells like smoke when i turn it on it turns off
get anew if you don't it will probably burn down your house
Jul 14, 2009 | RCA HD52W59 HDTV Projection Television
No image and sound on the rca hdtv 50' power button flashing
sounds like a fly back problem
have a qulifyed tech check this out its high voltage leaking you are hearing.
esp if its a sqweek hiss sound.
Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv shuts off after awhile
DEAR fleming_pj
OPEN YOUR TV AND TRY TO RESOLDER ANY LOOSE CONTACT.
OR CHECK POWER SUPPLY UNIT .IT COULD FIX YOUR PROBLEM.
OK
Nov 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52 inch hdtv turns itself off after a few minutes
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WM24 52" HDTV Projection Television Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
