Question about AEG Lavamat 12710 Front Load Washer / Dryer
Aeg lavamat 12710 stops after 5 minutes and goes to 0
The machine starts on any program, take water but after 4-5 minutes take all the water out and stops. No error codes on display. Any ideas?
4 Suggested Answers
SOURCE: AEG Lavamat Turbo 12710 Update - Dryer program
Hi Brooks, did you solve this? I have same issue
Posted on Jan 03, 2011
Daniel S
  • 4323 Answers
SOURCE: Changed PCB on AEG Lavamat 12710 Update, have
Hi
E90 is a communication error between the user interface board and the control board and during the procedure one of the connections is loose. As you have already replaced the PCB then please check the wiring harness from/to the PCB. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 11, 2011
adrianaloret
SOURCE: AEG Lavamat Turbo 12710 update. Machine is
hello i have the same problem has the person above said but cant find the brushes on the motor, what can i do ? NEED HELP PLEASE
Posted on Jan 23, 2013
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
On an aeg lavamat washer dryer l12710 where is the filter for the dryer I have cleaned the front one for the washer ?/
If you go to www.aeg.co.uk and look under "service and support" you will see a box to insert your model number. I've put your model in and there's service manuals in several languages. Happy hunting.
Nov 03, 2014 | AEG Lavamat 12710 Front Load Washer /...
ERROR SHOWS EF0, WHAT IS THIS
drain filter, overdosing of detergent or leaks water on the base.
Dado
Jul 28, 2014 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat Turbo 12710 update. Machine is AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts t
test the following steps and fix it. God bless you
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
If the washer won't start the line fuse might have blown.
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Jan 23, 2013 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts to flash. Door indicator light then goes from...
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
Jan 07, 2011 | AEG Lavamat 12710 Front Load Washer /...
I have a aeg lavamat turbo washing machine .when start it the water does not got to the drum ane water never stops simply running
You have a syphon - the waste pipe is probably too low and the end sits in water in the drain, meaning the water runs through the machine and out the waste.
Jun 30, 2010 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Lavamat
have youlooked in your manual it should have some codes in trouble shooting that will help you sort out the problem. hope this helps.
Jun 01, 2007 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat 12710 Front Load Washer / Dryer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
