Question about RCA F31672ET TV
Shrinking pic after 10-15 min
I have a rca f31672et tv works fine until it warms upthen the pic starts to shrink until only a horizontal line is left in the center of the screen
jomaru
  • 337 Answers
SOURCE: Flickering Picture?
Your set might have a high voltage leak and that is the noise you hear when is showing the screen problem or even maybe an arking too ,either one is related to the high voltage and it can be dangerous,if you are familiar with tv service you can try to see where is arking and replace the part with an exact replacement but if the set has a leak you will not see it and is not safe to be close to it,if you are not too familiar be safe and call for assistance from a servicer.
Posted on Oct 27, 2006
  • 556 Answers
SOURCE: 32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Posted on Sep 11, 2007
cancerags
  • 36 Answers
SOURCE: tv had burning smell and picture was shrinking on sides.
Hello dcook,
Yes, you are right. A good quality TV set should last for a few more years. Unfortunately I do not have enough information from your description of the problem to even try to make an educated guess of what could be wrong with your TV set. There are many possibilities. There are also a few things you can do to fix the problem: 1.- The obvious first: Check with the manufacturer or place of purchase if the item is still under warranty. The user's manual always offers assistance phone number(s). I do not know if you have extended warranty for the set, if so, that will pretty much take care of the problem. 2.- Contact a reputable, licensed/insured repair company to give you a repair estimate. There are many repair companies nowadays that will go to your home, troubleshoot the problem, give you an estimate and even sometimes repair it on site. A lot of them will reimburse you the cost of the estimate/service call if they repair it. Try to get at least two opinions/estimates for your protection.
Hope this helps. Let me know if we can be of further assistance.
cancerags
Posted on Dec 29, 2007
BFixed
  • 104 Answers
SOURCE: 27V412T turns self off
You have a bad vertical deflection IC and/or bad capacitors in the vertical circuit. The parts are inexpensive and can easily be replace by a service technitian.
Posted on Mar 14, 2008
jerryg50
  • 1667 Answers
SOURCE: RCA pix tearing horizontal lines
Get an ESR meter and check all the electrolytic capacitors in the set! I am sure you will find many decoupler and coupling capacitors that are on the edge or too high in ESR.
Jerry G.
Posted on May 25, 2008
MY TV TAKES TIME TO START
Check its power supply regulator section circiuts and horizontal output circuits for damaged component/s.
Aug 06, 2012 | Televison & Video
HP 7540 crt monitor shrinks to a horizontal line
It would be more economical to purchase a new or used LED/LCD display rather than wasting money on an old CRT monitor.
Feb 22, 2012 | HP COMPAQ 7540 CRT Monitor
When I turn the T.V. on The screen shrinks and becomes distorted. After it warms up It becomes more clear and works fine.
If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Picture tube problem
This problem indicates a defective vertical IC or dry solder joints on the IC connections.
Jan 27, 2008 | Televison & Video
RCA F36676ETFM2
it sounds me that it is due to cable wire connection where it is connected is probably might be loose or if you have cable box there is some loose connection.
Oct 05, 2007 | RCA F31672ET TV
RCA F31672ET No Power only a whining noise when plugged in Please help
Most likely you have a bad flyback transformer and shorted horizontal output transistor. The whistling sound that you hear is the power supply telling you that it has a short in one of the circuits it powers. Most likely the circuit mentioned above. Stargazer
Mar 06, 2007 | RCA F31672ET TV
Picture Shrinks
It is in the power supply or I would guess most likly in the horizontal sweep section of the tV set. MOST of the time, if the power supply is going lower in voltage, the set will shrink in width,BUT will also shrink in vertical size. If this is not happening, then I would say it is in the horizontal drive circuit. This is not a circuit a user should be experimenting with, as this is the HIGH VOLTAGE circuit and can pack a mean punch! Please if the sets less the 4 to 5 years old you may want to concider an estimate or replacing the set. Its all up to you. GOOD LUCK
Oct 07, 2006 | Philips 8P6034 TV
Televison & Video Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
