Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
PAnasonic TX-P42GN23 - red LED blinking 4 times....
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
SOURCE: panasonic viera hd tv th 50pz80u
We had a Pioneer that did the same thing. We called a Pioneer Service Center. It appears there was a recall on the Power Supply. They fixed it in our home at not charge.
Posted on Jan 07, 2009
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Posted on Oct 06, 2009
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
  • 8457 Answers
SOURCE: TV will not turn on. Problem with the Panasonic
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same result.Mean ur tv power supply board have problems and the causes.That the board,where the power a/c plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jan 19, 2011
My Panasonic TX-P42-V10B Plasma screen does not power up.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 08, 2016 | Panasonic Televison & Video
Panasonic TX-L42E5B blinks 3 times which board is faulty
When an abnormality has occurred to the unit, the protection circuits operate and set the unit to stand by mode. At this
time the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Fault maybe on the A board 3.3V SOS give me your email & i send you the full timing chart.
Apr 04, 2016 | Panasonic VIERA TX-L42E5B 42" LED TV...
Panasonic LCD TH-L32C2OM when I on the above lcd tv green led blinking and within few seconds red led blinking 4 times
Looks like a power supply trouble or capacitors not good. Has to be open and check by a pro. Good luck,
Serge.
Dec 27, 2015 | Panasonic Televison & Video
PANASONIC TV P42ST30B JUST WENT OFF NOW RED LIGHT FLASHES 7 TIMES, STOPS, THEN FLASHES 7 TIMES AND SO ON
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 10, 2015 | Panasonic TX-P42ST30B 42" 3D Plasma TV...
Panasonictv TX-L42S10B has 4 red light blinking and does't come any sound and picture just stop
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 13, 2014 | Televison & Video
TV stopped working, how can I fix the problem below?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 12, 2014 | Panasonic VIERA TX-L32X5B 32" LED TV...
Tx p42s20b panasonic tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 08, 2014 | Panasonic Televison & Video
RED LED 2 BLINKING TX-32LE75C1
Likely the power supply board, here is a comment from another expert here regarding this set:
Check or have a repair tech check connectors AP1 and AP2. Vibration rattles the power supply board (a crappy design, as the board is almost "floating") and causes the wires in the connectors to break, and may make intermittent contact. Heat may also cause intemittent contact. A very common flaw.
May 02, 2012 | Televison & Video
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
