Question about Dewalt 1 9/16" Rotary Hammer Drill D25551k
Drill will rotate but will not hammer under load
    Sergeant:
    Champion:
  • 226 Answers
Most of these types of tools have a manual switch it will be located on the body of the drill just behind the chuck on top or bottom or oposit the grip handle. some models have 2 switches.you want to make sure the switch points to the picture that shows a hammer and drill together.also rember it needs to have down pressure for the hammer part to activate.
Posted on May 26, 2009
My Hilti TE 17 roto hammer rotates but wont hammer
This one should have a knob or lever on the side of it to switch between "drill" and "hammer plus drill" It can be used as either a regular drill or a hammer drill.
Nov 13, 2014 | Drills
Keeps switching from hammer to drill
There is a spring loaded detent that keep the switch from moving. It is either dirty or needs replacing. The whole front of the unit needs to be opened to access it.
Is this your unit?
Parts:
Website: www.ozito.com.au
Email: enquiries@ozito.com.au
I hope this helps. Please give feedback.
J
Dec 09, 2013 | Drills
Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Feb 15, 2012 | Dewalt Drills
Will it go back and forth as well as rotate?
depends on the drill. give me the brand and model number and I will try and help. Some hammers have a selector on the side to go from hammer drill to hammer and then drill only. Let me know and I will try and help
Jan 08, 2012 | Dewalt Drills
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Makita 6935FD has lost all torque. The drill varies speeds when not under load, but won't drive a screw. The battery is charged. If I get the trigger in just the right place the drill will hammer once,...
Remove the brush caps and have a look at the brush length.
If they are extremely short, or barely touching the commutator bars on the armature, you will need to purchase a brush set part # (193466-2). The way you are describing it behaving without a load, and charged battery, I can only assume this will fix it. The other thing you can do is open the clamshell housing and with a pick, attempt to move the armature fan and see if it will make several full rotations. I want to know if a piece of the magnet ring broke loose and is rolling around between the armature and the magnet ring causing your varying RPM.
Nov 20, 2010 | Makita Drills
Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Jun 16, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Rotary hammer won't rotate, hammers very good
Unscrew the brushes and take a look at them. It sounds like you need new brushes.
Apr 06, 2009 | Drills
Hammer Drills differnces
Hammer Drills combine the rotation of a regular drill with a pounding action. These two actions enable the hammer drill to bore holes in masonry quickly without burning the bit.
Aug 27, 2008 | Dewalt DC2PAKCA Heavy Duty Xrp 18V...
Dewalt 1 9/16" Rotary Hammer Drill D25551k Logo
525 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
