Question about Dryers
Dryer won't heat up
My kenmore gas dryer does not heat up but runs. Do I need to replace the glow plug?
    President:
  • 1,136 Answers
HI, Can you see the ignitor glow at all? If not, check the thermofuse first. It is located on the blower housing white, /4" wide, & 3" long. If you can remove the rear panel on your model, that is where the fuse is located. If you can not remove the back panel, some models you have to remove the whole front panel and some the lower half front panel comes off.
If the ignitor does glow, you will need to replace the coils on top of the gas valve.
I hope this helps. Please let me know if I can assist you further.
Vic
Posted on May 19, 2009
My Kenmore gas dryer 110.97566210 works and heats when starting cold, after several cycles, the ignitor glows but the gas valve won't re-open. Is there a high limit sensor? i read a faulty ignitor can...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101=-=-
Aug 05, 2011 | Dryers
The Kenmore dry glow plug lights but the gas only comes on initially. After a few min the gas goes out and the plug glows periodically but no flame
heatman101
Jun 27, 2011 | Kenmore Dryers
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
Kenmore dryer not heating up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | Electrolux AEQ8700F Electric Dryer
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
My kenmore dryer does heat up all the time.
After the glow plug starts glowing a sensor detects this bright glow and turns on the gas which will be ignited by the glow plug and you have flames.
So, it could be this sensor or in the gas valve solenoids. You will need an OHM meter to check this.
Dec 21, 2008 | Kenmore Elite HE4 Electric Dryer
No heat
Check the glow plug.
Take off the bottom front panel, push the start button and look for a red glow. This glow plug is about the size of your little finger and is hard to see when it's off but you will see a red glow if it's working. No glow, replace the glow plug.
If it glows for a few seconds then goes out then the solenoids on the gas valve should be checked with an OHM meter.
Dec 16, 2008 | Dryers
Roper gas dryer not heating
the glow plug (ignitor)must draw 3 amps or more to function properly if its ok check the flame sensor for continuity located on the side of the burner housing and if its ok then the gas coils on the top of the gas valve are faulty let me know if this helps
Sep 11, 2007 | Kenmore 74962 Gas Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
